1
Bolt in!!!!
What do those motors put out?
-Alex
this is rad! Excited to continue seeing updates and get your thoughts on everything when complete!
I can't use all of the 19hp I have in my K-Pipe, I can't comprehend 30hp in a Grom
Throttle bodies and radiator connected in.
Struggling in both.
Radiator has that one bolt for its mounting point. Also the horn bracket keeps hitting the radiator and I can’t turn the bike fully on either side.
Throttle bodies are all pieced and connected together but I couldn’t use a return cable. The Grom and CBR cable was too short. Not happy with the way it’s routed but i haven’t found a better way. The spring is at the bottom and it’s an awkward angle for the cables.
Got the exhaust mocked up as well. It doesn’t connect directly to the can which is a huge disappointment. Also super far away for an under tail bracket.
There’s no brackets to secure the pipe so I see this being an issue later as well.
Also couldn’t remove the exhaust gasket in the motor. I have a new one, but might have to leave the old one in there.
Jimmy, check out Venhill for the throttle cables. I linked their part finder, you can search by bike. When you get to the specific product, there’s a checkbox at the bottom to add additional length.
Degsy just ordered from them and it was delivered a few days after ordering, very good quality.
