Page 4 of 4 FirstFirst 1234
Results 76 to 92 of 92
Project: Grom 2.0
  1. #76
    Re: Project: Grom 2.0
    Goodbye Grom charcoal canister. Keeping the bracket mounted to use for all the aRacer wiring that will go there.
  2. #77
    CBR300 motor is ready.
  3. #78
    Here is the adapter bracket to bolt the 250/300 motors into the Grom frame.
  4. #79
    TWINS! xrocket21's Avatar
    Central Maine
    Bolt in!!!!
    Lifer obsolete's Avatar
    Norf Sho
    What do those motors put out?
    -Alex
  6. #81
    from wiki
    Power 30.4 hp (22.7 kW) @ 8,500 rpm (claimed).[23]
    Torque 20 lb⋅ft (27 N⋅m) @ 7,250 rpm (claimed)[23]
  7. #82
    CBR300 motor bolted in and torqued.
    I used Grom torque specs (45 N-m) for the bracket to the Grom frame, and CBR torque specs (33 N-m) for the motor to the bracket.
  8. #83
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    this is rad! Excited to continue seeing updates and get your thoughts on everything when complete!
    that top motor mount bolt took two nights, and finally 2 neighbors to get it through.
    tomorrow i'll get the throttle bodies done and maybe some of the plug-n-play connectors
  10. #85
    I can't use all of the 19hp I have in my K-Pipe, I can't comprehend 30hp in a Grom
  11. #86
    there's people on the swap group that punch their 300 out to 357, port and polish the TB's and get upwards of 40hp+
  12. #87
    Central Maine
    But will it wheelie?
    i'm curious what this 300 will feel as my high compression 181 Grom power wheelies in 1st gear with me sitting down.
    the 300's have a really bad flat spot mid range that the aRacer does fix over time.
  14. #89
    Norf Sho
    Will it not wheelie I feel is a better question.
    -Alex
  15. #90
    Throttle bodies and radiator connected in.
    Struggling in both.
    Radiator has that one bolt for its mounting point. Also the horn bracket keeps hitting the radiator and I can’t turn the bike fully on either side.
    Throttle bodies are all pieced and connected together but I couldn’t use a return cable. The Grom and CBR cable was too short. Not happy with the way it’s routed but i haven’t found a better way. The spring is at the bottom and it’s an awkward angle for the cables.
  16. #91
    Got the exhaust mocked up as well. It doesn’t connect directly to the can which is a huge disappointment. Also super far away for an under tail bracket.
    There’s no brackets to secure the pipe so I see this being an issue later as well.
    Also couldn’t remove the exhaust gasket in the motor. I have a new one, but might have to leave the old one in there.
  17. #92
    Jimmy, check out Venhill for the throttle cables. I linked their part finder, you can search by bike. When you get to the specific product, there’s a checkbox at the bottom to add additional length.
    Degsy just ordered from them and it was delivered a few days after ordering, very good quality.
