Page 5 of 5 FirstFirst 12345
Results 101 to 124 of 124
Project: Grom 2.0
  1. #101
    TWINS! xrocket21's Avatar
    Central Maine
    Re: Project: Grom 2.0
    Auto tuners work SO much better when they are plugged in....
    Lol, we've all been there
    Feb 2011
    Somerville MA
    Really appreciate all the progress and consistent posts, Jim. So many steps of this are beyond my personal "yeah I'd try that" limit; great to see you working through the stuff as it arises.
    -Jared
  3. #103
    Bent the foot brake lever to clear the case cover
  4. #104
    Finally got the exhaust mounted and it’s super tight to the frame
  5. #105
    Trimmed the rear tire fender to fit with the exhaust
  6. #106
    300 swap header is 51mm OD.
    LeoVince can is 53mm ID.
    Weighing out options to have the header flared, clamp it, or get a can that fits better.
  7. #107
    Found someone with the tuning cable to connect the laptop to the bike, but figured out I can download the Bluetooth link app on the laptop to flash the ECU via laptop Bluetooth.
    Selected the 2018 Grom stock map and we’re off…
  8. #108
    Now that the flash is completed, my mobile app is showing other bike models, like it should have been.
    Now my ECU is mapped correctly.
  9. #109
    Current issue is there are still no RPMs on the dash. Will keep troubleshooting that.
    The bike is essentially ridable once the front sprocket arrives.
    Remaining list:
    - order new muffler (tomorrow)
    - install new O2 sensor (arrives Monday)
    - install crankcase breather filter (arrives a week from today)
    - oil the air and breather filters
    - install chain
    - install plastics
    - trim front plastics to fit radiator
    - setup dash again
  10. #110
    my fabricator just welded my muffler 1.75"id to my header pipe 1.25"id . he made a short cone shaped flare for the transition
  11. #111
    Central Maine
    I had a ton of problem flashing my RC8R, turns out you can see and monitor, but you can't flash over bluetooth for me!
    the aRacer stuff is made for bluetooth tuning and config
  13. #113
    spoke to one of the experts that know this stuff and he recommended using the 2016 Grom map as a base model for all 2016-20 models.
    flashed the ECU again and set it up for auto tuning and fuel
  14. #114
    RPM on the dash fixed with flashing the 2016 Grom.
    New Hindle muffler arrives tomorrow.
    New O2 sensor arrives Monday.
    Crankcase breather arrives Tuesday.
    No update on the front sprocket.
    Killed my new lithium battery from all the ECU and dash config and starts. Swapped back to the OEM till I get a lithium charger.
  15. #115
    You can use a regular charger, just unplug it once it says the batt is charged to keep it from cooking the batt in float mode, no worries.
    Central Maine
    ehhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
    Ok, don't let it try to desulfate either, if it's one of THOSE chargers.
    i have two lithium chargers in the trailer. i'll grab one next time i'm there. no issues using the OEM battery for now as that is plugged into a battery tender
  19. #119
    Hypertarded
    RI / CT border
    2 mm, could ya just use a tail pipe expander?
    Yes but then I’m stuck with a discontinued muffler if I need to replace it for whatever reason.
    Rather get something that I knew fits and is still in the market.
  21. #121
    Pipe expander now, rent/borrow, get things mounted and running. Pocket the cost of the exhaust... then down the line, if the bad thing happens, spend the money then?
    for the extra $150, i'll do things right the first time.
  23. #123
    what's right ? I say weld it on, if you want to replace, cut it off weld a different one on no worries about loose clamps, leaky joints
  24. #124
    Ok, $150, go for it. I was thinking it'd be $500 or more.
