Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
Putting grips on
    Re: Putting grips on
    Hair spray.
    Lifer Dip Dungles's Avatar
    Chilling with Dick Hurts
    I've always used brake cleaner.
    1.) Cut off old grip
    2.) Clean bar with brake cleaner thoroughly
    3.) Saturate bar and spray BC into grip
    4.) Slide on while twisting
    5.) Safety wire both grips
    6.) Wait a few hours for the BC to evaporate
    Done and works every time.
    Shannon
    Whats the deal with safety wiring grips?
    '02 F4i
    Quote Originally Posted by Kazinator View Post
    Keeping them from turning while you are riding...ie. slipping. Which isn't necessary if you use hair spray, spray paint, or grip glue. Which is why I use hair spray. No safety wire.
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    just use wd40 - works perfectly
    WD40 and compressed air
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    I don't use pro grips anymore they wear out in like a season and a half for me if I'm lucky. I have galindos super bike grips on there now and like them quite a bit. They also have nice groves for your wire and they are a little larger in diameter than the pro grips so they are more comfy for my big hands.
    All of the above for grips that either won't get wet, or won't have a ton of force applied to them (like a streetbike).
    For a dirty or track bike, glue and safety wire, all the time. There's nothing worse than a spinning grip when your trying to hold on for dear life.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Bump-
    picking up some grips today. Anyone use Progrip 699's?
    I have them on my bike. I needed something quick before the season started and that's all Bettencourts had. I don't like them very much. For a streetbike they'd probably be good though.
    you're holding on too tight
    Yeah? Come play in the woods, bin it in some water, and then try and hang on while both grips have throttle-grip. Oh yeah, don't forget, I'm throwing that thing around like wethefuckingpeople.
    Bridgewater, MA
    you have dual throttles on that thing. no wonder you gotta grip the shit out of it
    Central MA
    For dirt riding I have found that everything except crazy glue or grip glue with safety wire will come loose once the grips get good and wet. Hair spray, WD-40 (let sit over night), and spray paint all work OK, but only for a little while.
    I'm just going to put the grips on, and then drill two holes through the grips, the bars, and back through the grips and bolt the bastards in place.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    I use spray paint.. and the cheaper the better
    Posted by Jane in BoxChat
    Banned G21forme's Avatar
    Lakes
    What chip said, for street and track I always wire my grips and even if you aren't holding on for life it helps keep them from slipping while loading/unloading a bike off of a truck or trailer.
    Mar 2011
    Compressed air and they are on in about 2 seconds.
    Easiest thing to do.
  1. take-off/put-on Grips
    By JonT in forum General Bike Related
    Last Post: 05-24-10, 11:16 PM
  2. Putting together a CB200
    By JCorral in forum Welcome and Intro
    Last Post: 07-13-09, 08:42 AM
  3. Grips on R1's
    By Jim in forum Bike Maintenance
    Last Post: 02-25-09, 12:55 PM
  4. Putting a bike in the basement?
    Last Post: 01-09-03, 10:21 PM
  5. "Hot Grips" heated grips
    By interceptor in forum General Bike Related
    Last Post: 11-13-01, 04:32 PM
