Results 1 to 21 of 21
Remove Tank
    ride like you got a pair
    Jul 2008
    East bum f*ck Athol, MA
    Remove Tank
    How do I go about removing my tank off of my k7 GSX-R 750. I just got my LED lights in and it says its recommended that I remove the tank. I don't want to pay the money to have them installed if I don't have to. Thanks for any feedback.
    Nov 2004
    Boston, MA
    Re: Remove Tank
    Remove the tank and replace it with LED's?
    Brilliant!
    This will be the fastestes jixxer evah!
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Lifer Pittenger5's Avatar
    Austin
    Re: Remove Tank
    Look, I gotta be honest. Im all for LEDs unlike some people on this board, but if you cant get the damn tank off without help, just pay someone.
    Zip Tie Alley #505
    Meriden, Ct
    Re: Remove Tank
    I can't believe I'm about to help you install LED's on a perfectly good bike...
    Remove the seat. (two small allen bolts, 4mm, on either side of the seat)
    Remove the big allen (6mm) bolt at the front of the tank.
    Retrieve the tank prop rod from under the rear seat.
    Prop up the tank using the rod and disconnect all the stuff from the tank (two vent hoses, they slide off. The fuel line from the bottom of the pump. Pinch the gray tabs and the coupler will slide off. Unplug the power for the fuel pump.)
    Remove the bolt holding (and now acting like a hinge) from the rear of the tank. It's one 5mm allen that goes all the way through the tank hinge and into the other side of the frame.
    Carefully lift the tank off of the bike.
    Now that I've told you. I must warn you. Removing a gas tank from a sportbike is pretty basic stuff. If you're not confident at that... You probably shouldn't be handling the install of electrical components...
    Go pay someone. Or call Jim....
    I Dance With Will
    Oct 2002
    unknown
    Re: Remove Tank
    did you forget to empty the tank first or get ready for gas spill and warning to smoke while doing it?
    "fuckit!"
    Meriden, Ct
    Re: Remove Tank
    Nope, didn't forget a thing...
    Not a drop will be spilled after the quick disconnect is removed. I had my tank off yesterday, it was half full, no problem.
    Re: Remove Tank
    Quote Originally Posted by GixxerK1ng View Post
    Throw a stick of dynamite at it.
    In all seriousness, based on your question, don't attempt this install. Bring your LED's up to NH this weekend and I'll do the install slicker-n-baby shit.
    Lifer Punjistick's Avatar
    Norwell, MA
    Re: Remove Tank
    http://cid-cde75cc56bba5d78.skydrive.live.com/self.aspx/Public/GSX-R750|_K6.pdf
    This is a manual for a K6 but the steps are basically the same.
    Re: Remove Tank
    i can help you. but only because you have a gixxer & are installing LED's. you probably dont have to remove the tank, just prop it up. i dont have a prop up tool, so i just use a hammer on the air box to hold the tank up.
    fair warning: you may end up asking to delete this thread when you turn into a pinanta for asking a gixxer, LED and simple question.
    Jul 2008
    Re: Remove Tank
    Thanks to everyone that gave me the helpful hints, to everyone that wasted 3 minutes of their lives to flame me for asking a simple question go F#&* yourself
    Re: Remove Tank
    Oh, In that case Take the bolts out and pull hard if it does not come off pull harder, it will come off
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Austin
    Re: Remove Tank
    Im not trying to flame, but if you cant get the tank off, which is probably the easiest step of installing LEDs (trust me, I've done them) you're probably going to want to have someone do them, or at least help you.
    Zip Tie Alley #505
    Jul 2008
    Re: Remove Tank
    Quote Originally Posted by Mongoose441 View Post
    and another one chimes in
    pittenger I wasn't refering to you, you gave me some honest feedback. Thanks
    Re: Remove Tank
    fuggan zip tie alley
    Re: Remove Tank
    I did not say its the right way but The tank will come off. Noel(Gixxer jockey) Gave you the info Just look at the stuff. and make sure it goes back on the same way. Its not surgery.
    Jul 2008
    Re: Remove Tank
    who does installs around central mass that won't cost me a ton of money?
    Foxboro, MA
    Re: Remove Tank
    you're best bet is to try to fit your head in the blender - from there, turn blender to ON and choose Purree setting
    im kidding dont do that
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Re: Remove Tank
    download the manual..everyone one should own the service manual for their bikes imo, lot of good info in there. Learn your way around the bike
    JACKASS hammadown's Avatar
    Hopkinton, MA
    Re: Remove Tank
    Def dont try this on your own. Not trying to flame, but if you can't look around and find the bolts to get a tank off you dont want to be splicing into you electrical system. you have an offer...its worth the drive, bergs knows what he's doing. Any shop worth going to will charge you a good amount...and as PK says, if you can't afford to do it right how are you going to afford to do it over. Words of wisdom.
    Now go find that blender :
    Zip Tie Alley #237
    I Dance With Will
    Oct 2002
    unknown
    Re: Remove Tank
    this true for other bikes? i always spill a little even if i suck the tank dry. i must have done something wrong or is this a gixxa thing?
    "fuckit!"
    Re: Remove Tank
    this sounds so wrong....it's just too easy
  1. How to remove mirrors
    By dingley00 in forum General Bike Related
    Last Post: 06-17-13, 07:48 PM
  2. remove front blinkers 02 r6
    By burtonboarder23 in forum Bike Maintenance
    Last Post: 04-28-11, 07:31 PM
  3. Remove front fender?
    By HBerry in forum Bike Maintenance
    Last Post: 06-26-04, 09:49 PM
