Results 1 to 4 of 4
For those that ride/race SV650's at Loudon
    Member WOTEugene's Avatar
    Jul 2004
    Allston, MA
    What sort of gearing do you use on your SV? What gears do you like to enter which turns with?
    i dont know if we should give that kind of info out to the public
    ....... Nazo's Avatar
    Jul 2004
    Ox...I doubt you have much to worry about after how you were running this weekend......Fockin Fast!
    ...Now Chad on the other hand???
    WOTEugene......I had the same question the beginning of the season for my F4 and found out alot of it is preference and experience. Depends on what kind of times you are running.
    So, no definate answer is what I concluded.
    I personally think higher gearing helps when you are starting out and then lower your gears as you get faster in that gear.
    Just the opinion of a rookie racer.
    Chris
    LRRS Expert #160
    i dont really count gears, i think im in 4th in the bowl. if that were correct then i could figure out what gear im in around the rest of the track
    if you just learning then you could probably do the track in 3rd (except the front straight) without shifting. but shifting is so much fun. especially at full lean when you grab a gear and the whole bike shimmys as the STOCK suspension desperatly tries to maintain traction as the front wheel gets REALLY light and the handlebars feel like air as they sway around when you try to change direction................... and thats just turn 4
  1. Replies: 2
    Last Post: 10-17-13, 07:04 PM
  2. My 04 R6 race bike for your race/track sv650
    By eforer in forum For Sale
    Last Post: 05-23-12, 09:55 PM
  3. Loudon Race Schedule?
    By TOMIMOTO in forum Pit Area
    Last Post: 04-18-10, 11:56 AM
  4. Since when do we race these at Loudon?
    By Doc in forum Pit Area
    Last Post: 01-30-08, 04:07 PM
  5. 1st Race Weekend At Loudon
    By Stoneman in forum Pit Area
    Last Post: 04-27-02, 06:32 AM
