Suggestions on rigging ghetto-fabulous headlights (they don't have to work well, just make me barely legal) on track plastics? I miss street riding but don't think I will have functional street plastics in the near future. Discuss....
- Jamie
2009 K 1300 S
what's the difference between a street upper w' headlights and turn signals, over a track plastic with lights?
PVC pipe, a car headlight projector, and a hole saw
wal-mart fog lamps or something similar, saw a guy on 600rr had done it, he actually has them for sale but there mounted to the 600rr headlight wiring harness not an r6 wiring harness
Corey
Another question... Say the easiest thing ended up being cutting out the track plastics to accomodate my stock headlights, what would be the best thing to use to cut them so I don't trash them?
I think you should find some auxilary lights that clamp on somewhere. kind of like the ones cruiser guys mount on engine crash bars or those ones that mount near the bottom of the forks. remember you also need a tail/brake light and directionals.
LRRS Am #331
I used my dremil tool to do that on my 600rr
LOL! I got that part..re-read my question...particularly the end of it.
what I meant, is: why would you add lights to the track plastics, when you could just get an OEM upper w' lights on it to swap into its place?
I figure the fit/finish/mount and light patterns would be better with an oem headlight setup (turn signals included).
is the upper fairing on the track plastics integrated into the lower part?
Acerbis cyclops street fighter headlight. It won't throw a ton of light but it will be enough to get you by and its dot aproved and really easy to mount. You'd have to pull your upper to use it though. Where are you stock plastics?
I don't know about Mass but in VT the lenses for headlights and turn signals are supposed to have DOT embossed on them to pass inspection. If you are looking for a truly street legal setup (ie able to pass inspection) than you may want to go the dremel route instead of the Walmart POS fog light direction.
LRRS EX #7
Low Down Racing
Because I havn't found a good OEM upper to replace the one I just busted, because I have no $, and because I want to ride ASAP and I may not find a used upper in decent condition for a while (believe me, I've been looking) and don't want to lose out on the rest of the riding season.
Its not that easy to find OEM plastics for a 10 year old bike that are in decent condition...
You could take off all the plastics on the front and mount a round headlight.
It won't be pretty but it will work
Could you mount something under the front fairing above the wheel? Not sure of the clearance you have...
If you go the dremel route I have the regular one and the multimax that you can use :-)
Check out the Delkavic products on Ebay.
I got the Red bull set shipped for $600. Excellent fit.
Even thought they say that there is a long time to ship them out. Call them before you order. I got mine in like 3 days.
This would look sharp..
http://cgi.ebay.com/ebaymotors/03-04...Q5fAccessories
YEA you get all those plastic pieces for that price
I know what you like.
The only thing about these is that they can scratch somewhat easily. I picked up a tail section on the track and put it on the tank cover. There were some light scratches from the tail section shifting around. But for replacements that fit like OEM, Look awesome, and save you a ton of $ it is well worth it.
Just don't forget, the days are getting shorter and it would suck getting caught out at night with shitty headlights.
My wife actually rides my racebike on the street. I have a cafe style headlight that attaches to the fork and a bolt on tail/turn for the rear. Add bar end mirrors and a kickstand and you are complete. The entire bike goes from race to street in 20 minutes.
from this:
to this:
the whole thing cost me about $120 to get it set up for street riding. Maybe something similar?
LRRS/CCS EX #29
434Racer Performance Parts / Motul / Sportbike Track Gear / Knox / Dyno Solutions / Tony's Track Days / MTAG Pirelli / Nexx Helmets / Woodcraft / GMD Computrack
