Results 1 to 10 of 10
single sided-swingarm folks!
    Jun 2005
    I want to machine up a bunch of adapters for my Pitbull rearstand to cover the single-sided swingarm bikes 1098, 848, SpeedTriple, etc...
    If you have one of these bikes and a reliable set of calipers (good to .001")
    could you do me a favor and measure the inside diameter of your rear axle and post it up?
    Or... better yet, if you have a rearstand for your bike, measure the stand pin.
    grassyass.
    Edit: looks like I'm all set for:
    Ducati 998/996/916/848/748, Super Motard, Monster S4R, Monster S2R, Multistrada 1000, M900E
    Ducati 1098
    Dec 2006
    Manchester
    Re: single sided-swingarm folks!
    HOW ABOUT MEASURING A PIT BULL STAND THAT HAS THE PIN ALREADY
    Lifer FirstDuc-1098's Avatar
    Central Mass
    pin on my 1098 stand - 1.668
    pin on my 748 stand - 1.012
    Nov 2004
    Boston, MA
    Wirelessly posted (Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 6.12) 320x320; VZW; UTStar-XV6800; Window Mobile 6.0 Professional
    the 1098 has 2 diff sizes depending on the axel used
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Senior Member spydah's Avatar
    Fitchburg, MA
    Are you going to implement a bearing as the pitbull pins do?
    Ducati 998/996/916/848/748, Super Motard, Monster S4R, Monster S2R, Multistrada 1000, M900E are all one size.
    1098 has two sizes. 43mm and 41mm
    LRRS #831 Novice
    2007 Ducati 1098 - Street (okay, sometimes track)
    2002 Suzuki sv650 - Pure track!
    2007 Suzuki sv650 - Next seasons track bike
    http://www.myspace.com/spydah77
    Lifer LuvDog's Avatar
    Ashland, MA
    Which axle side or both?
    2003 ZX7R
    1995 916
    Jun 2005
    Quote Originally Posted by spydah View Post
    Do you now if that's the ID of the axle or the OD of the pin?
    Thanks!
    Thanks guys!
    I'm primarily interested in the side of the axle that would allow for wheel removal (tire changing). Looks like I've got the 916 covered if it's the same as the 996. Not going to bother making a stand as I already have a PitBull, so I'll be making them to work with PitBull's standard Ducati stand (bearings, interchangeable pins).
    Fitchburg, MA
    Thanks!
    Thanks guys!
    ID of the axle I believe.
    I've got a buell pin that came on my stand when I bought it, found out after that ducati was different. If you want that measurment I can get it too, not sure what it goes to though. XB12 maybe?
    LRRS #831 Novice
    Central Mass
    my pin size of 1.668 works out to 42.37mm so 41mm and 43mm must be ID
    Lifer DuncanMoto's Avatar
    Ducati early 1098 pins from powerstands are 42.75mm (MV size too) Inside axle is 42.95mm
    Maybee my caliper is off .05 but either way it's safe to assume .2mm tolerance for the pin to axle..
    39.8mm pin size for the later (smaller) 1098 axles.
    Pin measurements from the PU catalog
    BMW: KS1200 s/r all 53.28mm.
    Ducati All except 1098 Left side 21.7 / All right 29.5mm.
    Triumph: All left side 27.3mm. / All right side 29.2mm.
    I have pins here if you want to come check them out.
  1. Wanted - Parts & Tools | WTB: Pit Bull stand to suit single-sided swingarm
    By number9 in forum Wanted
    Last Post: 12-01-16, 03:48 PM
  2. VFR800 Single Sided Swingarm Stand - Red
    By WinVT in forum For Sale
    Last Post: 09-02-11, 08:28 AM
  3. Tire change on MV Agusta (single sided swingarm)
    By jwm2k3 in forum General Bike Related
    Last Post: 07-28-11, 07:55 AM
  4. WTB: Rear Stand (Single Sided Swingarm)
    By LowSider in forum Wanted
    Last Post: 07-16-10, 02:49 PM
  5. Rear Stand for Single Sided swingarm?
    Last Post: 06-11-10, 03:28 PM
