Anyone have an 07 or later CBR600 and install dual steel lines?
I ordered them up, including a bleeder bolt for the master cylinder... but upon closer inspection I'm not sure if it will fit?
The 07 and later CBR's have the upper banjo bolt going straight down... and I'm afraid a longer bolt won't clear the fairings, etc.
Anyone do it?
There's a company called HEL that will custom build'em for virtually any bike.
http://helperformance.com/
Yep... the stock banjo goes straight down... never seen one like that before.
The stock setup only has a single line... and they put a 90 degree bend in it. (So it comes up from the brakes vertically then turns horizontal under the master cylinder.)
I'm worried there won't be space for two lines to come up and turn 90 degrees... plus the extra bleed nipple.
I don't know about stock stuff as mine has only had race fairings on it since I bought it and came with the SS lines and Woodcraft clip ons. I'm not sure the banjo bolt is gonna fit, if it does I'd bet it would be real tight. but with the bolt going up through the bottom of the master a bubble getting caught there isn't as much of an issue as it is on a radially mounted master.
if you're worried about it just get a Brembo that has a built in bleeder on top of the master![]()
LRRS Am #331
good point that the bubble is less likely to trap at the top with this setup...
You have a radial master. Shouldn't need a bleed nipple on the banjo bolt as there isnonenonntop of the master cylinder. No need for one on the banjo at the master.Originally Posted by 35racer
I put Speigler SS lines on my 08 CBR600RR before I sold it. It was one down from the master cylinder to the caliper (left or right, your choice I think) and then a double banjo at the caliper and a shorty "up and over" line to the other caliper. I know this isn't a true dual line setup but it worked really well.
no bikes currently
I also got a double banjos on the hel lines on my 07 600rr. Fairing clearance is fine with my race bodywork.
Yes, the 07 and up came with the radial master. It has a bleed nipple on top. It's next to the remote reservoir hose. A bleeder on the banjo is redundant.Originally Posted by 35racer
