7
That's the only replacement part I really need to get the bike back on the road. Figured I'd ask around on here before buying a new one. Got my left leg back up on the peg last night after having my stitches removed Tuesday![]()
I'll check when I get home tonight.
Roland Arsenault
LRRS and USCRA #763
check ebay before buying brand new. or get flush mounts![]()
I may have one. Are they the same as the EX500s?
2006 DRZ400SM
FYI if I remember correctly the left and right signals should be the same. Or as someone else said you could get a set of flushmounts for probably what you'd spend on a used OEM signal. On the EX250 remove the stalk from the baseplate and drill/mount the flushmount signal directly to it.
What year? I don't recall what I've got left in the closet, but they changed the turn signals in '06 or '07 IIRC (to look a little less 80s).
Edit: I've got a 2006/07 front turn signal. I forgot to check which side it was intended for, but they are reversible if you add a drain hole in the right spot. $25 shipped and Paypal'd if you want it. I've also got bits and pieces of an 88-05 signal, but I suspect you're not looking for the electrical-tape-and-zip-ties look.
Flushmounts are a good solution, IMO, as long as they don't cause inspection-related problems—they're a lot less vulnerable to tip-over damage and don't look nearly as goofy.
FYI: 1988 - 2005 are the same.
A couple of eBay postings, in case you strike out here:
http://www.ebay.com/itm/1988-2005-Ka...0492aa&vxp=mtr
http://www.ebay.com/itm/1998-Kawasak...7258d1&vxp=mtr
http://www.ebay.com/itm/1998-Kawasak...725997&vxp=mtr
http://www.ebay.com/itm/Kawasaki-EX2...881e9e&vxp=mtr
