Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
stripped fairing bolts
    High maintenance priss
    Central MA
    Re: stripped fairing bolts
    Quote Originally Posted by reiobard View Post
    2 more pieces, must be better..
    Its not the # of pieces i was comparing; the first type of extractor I find very useless; they do not grip well at all. They are sold as screw extractors...as in "wood screws". They will work OK in this regard. This type does not cut into the head at all, and those spiral flutes are not sharp...very dull in fact.
    The second type is basically a reverse cut drill and is better suited to the torque required to remove a bolt; it cuts into the head of the bolt.
    Try the first type if you'd like; chances are you'll be wasting your time. IMO of course.
    Lifer DaSarge's Avatar
    Oct 2002
    Cape Cod
    Well just came back and bought a 14.4v powerdrill and a extractor set and also a starter bit to make a hole for the extractor...Right now the drill is charging and hopefully this works and lowers the stress level. Makes me wonder what the guy before me was doing to these bolts...Lefty Loosey fucker.
    .50 cal should remove em nicely.
    If not, I'm sure you can fab up some kinda IED that'll take em out.
    Oct 2002
    Cape Cod
    It might have to come to that
    Oct 2007
    South Shore Area
    use left handed (powered extractor) drill bits or drill the head off the screw use the same diameter drill bit of the screw threads ,not the head if you know the size ..
    Member Rossy83's Avatar
    Apr 2008
    Brunswick, ME
    I use this when all else fails it works great for almost any application.
    Oct 2002
    Cape Cod
    Update
    Well after a few hours drilling into this damn bolt and going up a size with each extractor I finally got one out...Worst experience so far...Who would of thought that it would be so hard or am I just that dumb? Seems like a simple task but that bolt was completely stripped beyond belief...Tomorrow I will get the second one out when the drill is all charged and pick up some new bolts....Thanks for everyones help..Gotta love NESR....
    Did I mention I had to do this all with one hand because I just had wrist surgery yesterday
    Oxycotton
    Lifer BostonSVkid's Avatar
    Dec 2005
    This kind suck IMO, next to useless for bolts: Craftsman 5 pc. Screw Extractor Set - Includes Screw Extractors No. 1-5 - Model 66202 at Sears.com
    Honclfibr linked this kind, but also implied that they suck...which I'm agreeing with.
    This kind is better: Craftsman 7 pc. Drill-Out/Screw-Out Power Extractors - Model 720SR at Sears.com
    +1 I have these
    2006 Ducati Monster S2R800
    Lifer Punjistick's Avatar
    Norwell, MA
    Quote Originally Posted by Rattler View Post
    I just did this the other day actually. Drilled the head off the bolt and then I was able to remove the bodywork. With the rear tailpiece removed I was able to grab the bolt with some vice grips and back it out.
    Sep 2007
    Hinsdale, nh
    also the first type are tapered and have a tendency toflair the screw/bolt out inside the hole you drilled causing it to get even tighter, sometimes they work but not often, go with second type
  1. Stripped threads in oil pan
    By mi1knc0okies in forum Bike Maintenance
    Last Post: 07-28-12, 04:27 PM
  2. TL1000R race fairing & fairing support
    By jeffsv in forum For Sale
    Last Post: 05-07-09, 02:23 PM
  3. fairing bolts + bushings
    By flintoid in forum Bike Maintenance
    Last Post: 07-01-08, 11:37 AM
  4. Stripped bolt or pan?
    By FastJohnny in forum Bike Maintenance
    Last Post: 04-05-07, 03:10 PM
  5. stripped drain plug
    By Gangsta SV in forum Bike Maintenance
    Last Post: 09-12-05, 02:14 PM
