Results 1 to 10 of 10
tire plug kits
    tire plug kits
    I've had 3 nails in the last year of riding and was thinking about carrying a plug kit
    saw this thread and now realized there are different plug kits:
    http://www.nestreetriders.com/forum/...ace-patch.html
    which one do you use?
    I'm looking for something to get home with
    Douglas Ma
    Re: tire plug kits
    This is the kit I carry. It works well. I've used it twice. http://www.stopngo.com/products/Pock...Inflation.html
    Central Mass
    Re: tire plug kits
    i use whatever $6 generic sticky rope type kit an auto parts store happens to carry with a decent amount of cement. i've plugged a few tires with them and have gotten thousands of miles without an issue. an old roommate did it as well, but i think he was a bit sloppy b/c his leaked and he had to pull over on the highway. it wasn't a blowout by any means, just a leak that he easily managed to ride to a safe stop with. when he got home, i plugged it for him and he was good for the life of the tire.
    Junior Member sdavid's Avatar
    Jul 2008
    The town named after the river, without the "k" at the end.
    Re: tire plug kits
    Quote Originally Posted by bstnsboy View Post
    If the plug inserts from the inside why would you carry it with you?
    I have the basic Slime tire plug kit and a DC air topper. I installed a 12DC outlet on my Ninja and it has enough to run the compressor and can charge my cellphone if needed.
    Douglas Ma
    Re: tire plug kits
    You install the plug from the outside just like a normal plug.
    Quote Originally Posted by sdavid View Post
    Arlington MA 02474
    Re: tire plug kits
    After two punctures in 6 months, I carry a plug kit (got a good one at the local auto parts),
    ... and got the stopngo mini compressor, stows in the tailbag.
    "Measures: 4"x 2" x 6" and weighs only 14 oz."
    http://www.motorcycle-superstore.com...T.ac=SLIsearch
    Re: tire plug kits
    I stopped by autozone and found this for $8.99
    http://www.autozone.com/autozone/acc...er=486791_0_0_
    only thing they didn't have was a mini compressor, or CO2 cartridges
    can you just use a can of fix-a-flat to inflate the tire after it's plugged? I figure that's small, cheap, and readily available.
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    Re: tire plug kits
    If you even remotely like your mechanic (or the person who does your tire changes), don't use FixAFlat. That stuff get all over everything. pick up some CO2 cartridges or get a mini pump like someone else mentioned.
    Central Mass
    Re: tire plug kits
    i carry around pretty much the same thing, except i intentionally got the screwdriver-type handles so they take up less room under the seat where space is at a premium already.
    Sep 2010
    Re: tire plug kits
    I've used this one and the Harbor Freight equivalent and both have served me well. I've rode a plugged tire for 8k miles on an 800lb cruiser without issue. I also carry a $20 mini compressor from WalMart (powered by my cigg outlet) if I'm going to be out of pushing range of a gas station.
  1. Tire nail - plug, patch or replace??
    By Tekime in forum Bike Maintenance
    Last Post: 03-15-16, 09:53 PM
  2. Rear Tire Plug x2 Advice
    By rsw81 in forum Bike Maintenance
    Last Post: 05-04-13, 12:07 AM
  3. Tire Plug Kit
    Last Post: 08-25-07, 10:13 AM
  4. new tire plug question
    By oreo_n2 in forum Bike Maintenance
    Last Post: 08-13-04, 08:28 PM
  5. tire plug kit?
    By bemused in forum Bike Maintenance
    Last Post: 11-27-03, 08:42 AM
