Results 1 to 4 of 4
tire questions
    Westfield MA
    tire questions
    Hey guys, i got a few questions regarding tires and wheels.
    1. have wheel sizes changed on specific bikes over the years? or have they remained constant? for instance... would a 01-08 rim fit on my 88 ninja 600R?
    2. I have small cracks along the left and right side of my front tire, does it need to be changed? im assuming it does
    3. Are tires on bikes like tires on a car? i have an all wheel drive mitsubishi so when i need a tire, they recommend doing all 4 for even wear. is this the same on a bike?
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: tire questions
    yes
    no
    I think no
    yes
    no
    only 2
    Don't be cheap fool those tires are too old times 4
    Glen Beck is John the Baptist
    Re: tire questions
    rim diameter for sportbikes has generally remained the same at 17"..... but back in the 80's and 90's, some bikes had 16" or 18" rims.... Either way, swingarms & forks have evolved and with them so have axels, hubs, etc... which means you're gonna have to find a rim for YOUR specific bike (unless a rim from another kawi will fit, you'll have to do some research)
    cracks on a sidewall aren't exactly good... I wouldn't trust it.
    Yes, generally you want to replace in set sunless you're looking to replace w/ the same make/model of tire.... but if your tires are old & cracking it's probably time for new rubber anyways.
    Talk to BostonMoto, they're NESR's Pirelli Dealer & are the only tire guys I'll do business with up at the race track.
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Re: tire questions
    Quote Originally Posted by JunoAF View Post
    Doubtful. Not like a car with 4 or 5 hole pattern.
    You can change one without the other. But you get better performance changing both together. If you the front and rear tires end up being very different in shape and construction type it can change how it handles.
    The 88 Ninja take radials or bias ply? I WOULDN"T mix and match these!
    2008 Honda CBR 600RR
  1. Tire and brake questions
    By Fitz in forum Pit Area
    Last Post: 11-19-09, 10:54 PM
  2. Tire questions.
    By lopycam in forum Pit Area
    Last Post: 02-27-09, 10:17 PM
  3. Tire Questions
    Last Post: 12-20-08, 04:23 PM
  4. Michelin Tire questions
    Last Post: 10-18-06, 06:18 PM
  5. More Tire Questions...
    By Stoneman in forum Pit Area
    Last Post: 08-14-03, 03:11 PM
