Page 2 of 6 FirstFirst 123456 LastLast
Results 26 to 50 of 131
V-Twins Vs, Inline 4's
    granite state
    Originally posted by Ducrappy
    Actually my new plan is to do the valve maint myself over this winter. I'll be buying all of the necessary tools over this fall (and getting some for christmas) and will have an entire season to get it done in time for spring. It should only take a day or two, so the odds are good that I'll have it done by March
    so no more riding this year at all!?
    sounds like a good plan to do it yourself. save major jing.
    Lifer union's Avatar
    Blackstone, MA
    I like my twin. However my next bike will probably be an I4 600 class.
    James
    Tifosi RSVMILLE661's Avatar
    Oct 2004
    Somewhere between here and there
    Coming off of an RC-51 to a 600cc machine I get the feeling you maybe a bit underwhelmed. I know I was when I would ride my friends machines.
    Scott Major
    Ferrari Fix it Club Racing
    ALMS, SCCA, LRRS, CCS, FUSA #'s 161, 62, 676, 661, 205, 12, 60, 89...
    Karloff? Sidekick? FUCK YOU!! That cocksucker does not deserve to smell my shit!
    clack clack Ducrappy's Avatar
    Feb 2004
    New Ipswich, NH
    Nah, I'm gonna get a rear tire on it soon and ride till the snow falls, then worry about the valves after that.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Twins are ghey
    Every Jap superbike has more torque almost everywhere but especially over 3500 rpm
    We don't stay at twins rpm's cause there is another 50 HP right on top
    Yes a liter twin has more torque then a 600 inline.
    If you want the power buy the power
    1000 cc or bigger inline.
    Glen Beck is John the Baptist
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    your grest ritch lol
    Originally posted by richw
    Twins are ghey
    www.bostonmoto.com
    Forum Rules
    Blackstone, MA
    Its quite possible. I got the ride the zx-14 about a month ago and I was underwelmed by that thing as well. I know the 600 will not have the same output as the rc but Im looking at something a bit more civilized for the street. Hopefully I can find someone with one that will let me take it for a spin before I make the purchase.
    James
    Lifer ZX-12R's Avatar
    Candia, NH
    Underwelmed by a ZX-14? Are you sure all the plug wires were installed? Power wise the 14 is in an entirely different league then the RC-51 so I'm not sure how it was underwelming.
    Maybe you should check out an SV650. I've seen one that consistently beat an RC-51 up at New England Dragway
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Maybe that had something to do with the riders ability?
    Aug 2004
    Baltic,CT
    Allegedly the 14 is tamed up to 3rd gear
    Plus the power is metered out delibrately to the maximum dry traction.
    The only way to really tell is numbers or a roll on with someone in the power band
    granite state
    thats what i heard. electronically keeps it from full power in the first three gears. i'm sure somebodys already found away around it.
    Twins are ghey
    ummm.... my SV650 makes MORE torque than a zx6R
    and i think my SV1K makes about 80-85ft lbs
    Candia, NH
    It was a jab at 2 members of this board
    Power is tamed through 3rd gear at lower RPMs by the use of secondary butterfly valves in the throttle bodies. The computer effectively prevents WOT by modulating the air going into the engine. It is clearly something that was added because of the Kawasaki lawyers not wanting inexperienced riders looping the bike. In true Kawasaki form however, you can remove the secondary butterfly valves and return the bike to its maximum power.
    Oct 2004
    Twins are ghey
    Dude you need some depends for the mouth due to all the shit that is spewing out of it.
    My aprilia made 68lb feet of torque at 3200 RPM and max HP of 114 stock at 9800 RPM max torque was 74lbs. (all at the rear wheel.) I have yet to see a 1000 CC Machine post those numbers for torque so low. The new Mille's are posting 80lb feet of twist at 6500 RPM with 143 HP.
    Keep in mind the bike was 2000. 5 Try and find a comparable 4cyl machine. I had waaaay more twist than any GSXR 750, or ZX-9 for that matter.
    The ZX10 (according to sport rider) is pushing out 81 lb feet at 8500 RPM. This is the leading 4 cyl machine for HP and torque. It has 166 HP at 12000 RPM.
    I agree the 4 cyl machines have more top end HP but for point and shoot riding, you'll be hard pressed to beat a twin. Not to mention the italian twins (and jap twins) sound better than any 4 cylinder could ever hope to. ...to that I say good day sir!
    Scott Major
    Dec 2003
    Ma
    How much does your priller weigh?
    All the twins i've riden are pigs, though KB's hawk is comfortable. i prefer inlines. I also preffer two smoke dirtbikes. I don't like to klunk down the street, I like to scream.
    Oct 2004
    I'll be the first to admit that my Mille was a heavy handed tank. It came in wet (according to the scales in the garage at NHIS) at 468. Full fuel, oil and street plastics. I'm guessing 450 in race trim.
    They are not as flickable as the 4cyl machines but they are a lot of fun to ride. I look at the 4 cyl machines as scalpels that slice through the track and the twins as tanks that blast their way around.
    Scott Major
    Dec 2003
    Ma
    I'm curious, how do the twins slide? They have more consistant power so at a traction loss I would think that would be good, but at the same time lower RPM's so less gyroscopic.
    May 2002
    Meriden CT
    You can't ride twins ham fisted
    4 bangers are like riding automatics
    www.bostonmoto.com
    Forum Rules
    Oct 2004
    They slide ok. The front is kind of a slow wallow (on my bike it was anyway) the tend to underster a bit. Its predictable and tractable. The back is very easy to control with throttle input.
    I used to spin the rear up on my bike going up 3-4 and again outta 6 pretty consistenly. Not like a smoldering, blistering spin but enough to feel the back end twitch and leave a nice lil mark on the pavement.
    I found the gyroscopic force to be greater on the twins vs the 4 cyl machines. I think it is due to the heavy crank and much heavier pistons moving counter to one another.
    Edit: If by gyroscopic you mean getting the bike to turn in? As a whole they tend to require a bit more physical input. i.e. Bar input as well as leg input when pushing on the pegs to get the bike to rotate underneath you.
    Scott Major
    Candia, NH
    That is not exactly true. Any vehicle's peak acceleration is found at its peak power output, not its peak torque output. All other things being equal, a higher powered vehicle will be quicker than a less powerful one.
    In a motorcycle, I-4 engines produce significantly more power for any given displacement then the twin counter part. This is due to a number of reasons including combustion efficiency and engine balance. As a result, you will be hard pressed to find a twin that can out run an equivalent sized I-4.
  21. #46
    May 2002
    Meriden CT
    HP sells bikes, torque wins races ....
    www.bostonmoto.com
    Forum Rules
  22. #47
    Just Registered 13's Avatar
    Dec 2003
    Auburn, NH
    Does it really matter? They both have their places. I personally have always preferred the twin, I own two. Sure, the I4 will make more power. Put a better rider on a twin and he'll walk away from the I4 everywhere but the highway.
    And who races there anyway?
    There you have it, V's are better.
    One of the former LRRS #13's
    http://www.facebook.com/ChrisWatt762
    JT42
  23. #48
    Candia, NH
    Which is why you find so many Diesel engines on the race track!
  24. #49
    KB KB's Avatar
    Manchester NH
    I have a Superhawk and my girl has a cbr600rr.
    I have never been underwhelmed by her bike. If anything I want to sell my bike and get a newish 600. The new bikes are just silly.
    Or keep it just to have a v-twin around to rip some nice wheelies and use around the yard to tow trailers and pull stumps out.
    LRRS/CCS EX #13
    GMD COMPUTRACK
  25. #50
    Mar 2004
    Lynn, MA
    Re: You can't ride twins ham fisted
    Agreed. I know the liter bike I-4 is faster than a liter V-Twin, but to me my last I-4 was soul-less after I discovered the twin...
    Matter of fact, I want one of each. I nice CBR1000RR and an RC51. There that will take care of it. Or maybe a Aprilia RSV and an MV Agusta 1000F4...yeah...the second one.
  1. Inline 4 to a Triple?
    By csmutty in forum General Bike Related
    Last Post: 10-28-11, 09:32 PM
  2. inline 4 jap to a duc 848??
    By boloson in forum General Bike Related
    Last Post: 07-03-10, 07:02 PM
  3. twin vs inline?
    Last Post: 12-02-09, 01:28 PM
  4. V-Twin or Inline-4
    Last Post: 05-04-07, 07:46 AM
  5. Info about inline 4's and V-twins...?
    By marcv125 in forum Bike Maintenance
    Last Post: 02-24-05, 02:35 PM
