Results 51 to 75 of 79
Ultrasonic cleaners: you gotta get one!
  1. #51
    Re: Ultrasonic cleaners: you gotta get one!
    Anyone in western MA have one of these already? It's carb cleaning time...
    Dec 2003
    Ma
    I ordered one, it'll be at my place in a few days. The rental fee will be wrenching time.
    Oh, SWEET! I only need to use it once a year, so sharing is caring.
    I'm still debating on A) Cleaning my carb or B) Cleaning it by replacing it with one fresh out of it's shipping container...
    Ill be testing it this Saturday
    Member slideruleracer's Avatar
    Jul 2003
    Northeast
    Paul, I just got one today to clean the carb in the DRZ (and a clock movement for a grandmother clock I'm building...and my guns....). So come on over - and bring the mtb if you're still selling it!
    -Chris
    Lifer Pittenger5's Avatar
    Austin
    I picked one of these up since I have to clean carbs from 3 bikes. Any guidelines what to do? What not to do? I assume no rubber or plastic or anything in the cleaner, etc.
    Zip Tie Alley #505
  8. #58
    Lifer catamount's Avatar
    Sep 2006
    Colchester, VT
    I just did my 2nd carb yesterday. It's incredible how clean it came out.
    Rubber is not affected by Simple Green. It's safe. If the rubber is easy to separate, go ahead and do it but there is no real reason to leave it out. There have been a couple of occasions where I didn't want to remove an o-ring for fear of tearing it so I just threw the entire thing in there. From all of the reading I've done online, Simple Green will not break down rubber.
    Break down the carb as much as you can. Then fill basin 1/4 of the way with Simple Green. Fill rest of the space with water. Turn it on to 480 seconds and turn the heat on and let it go. I usually just keep it going for 10 or 15 minutes with the heat on, turning the part over every 5 minutes or so.
    The regular Simple Green will stain the aluminum if you leave it in the dirty water sitting still for too long, so after 15 minutes of running it I rinse the parts in hot water. Then you can run them again using the same formula, although you may find that they are already insane clean and ready for reassembly.
    After the initial 15 minute run I'll blow the jets and passages out with carb cleaner and them throw them in for round 2. By the end of round 2, your carb should be pretty much in new condition.
    Simple Green HD (available at Home Depot) is purple in color and apparently won't stain the aluminum no matter how long you leave the parts in. You could pick up some of that if you wanted to, but I use the original green variety and just make sure to keep turning the parts every once in a while.
    I think you'll be shocked at how well it works. I removed my 2nd carb from it last night after about 10 minutes of running and it looks nearly new.
  9. #59
    Quote Originally Posted by slideruleracer View Post
    -Chris
    Still holding the bike for you! I will deliver it personally soon!
    Quote Originally Posted by catamount View Post
    /Simple Green HD (available at Home Depot) is purple in color and apparently won't stain the aluminum no matter how long you leave the parts in. You could pick up some of that if you wanted to, but I use the original green variety and just make sure to keep turning the parts every once in a while.
    Simple Green HD MSDS
    Just did my chain and used simple green came out PIMP..................used a little heat in the bath and just like new Ran it 3:1 with a bit Xtra
  12. #62
    Austin
    Is this thing supposed to be making a constant buzzing noise? Or is it supposed to be far more active?
    Zip Tie Alley #505
  13. #63
    Constant buzzing noises.
    Dec 2003
    Ma
    This was the funniest thing I've read on the forum in a long time.
    Austin
    Holy shit! That is quite a compliment!
    Zip Tie Alley #505
  16. #66
    /He uses the original Simple Green, which *can* discolor aluminum if you leave it in the dirty water long enough without moving it around. That's why he suggests changing the solution out after the original cleaning.
    I've read that Simple Green HD (purple in color) available at Home Depot won't discolor aluminum.
    There is now a Simple Green Motorsports product, similar to their aircraft product, that supposedly will not corrode aluminum.
    Roslindale, MA
    Does anyone know if they are able to make the Ducati Mikuni CVs fit in the Harbor Freight cleaner??
    Wirelessly posted
    Quote Originally Posted by DesmoTull
    1 at a time, yes. Not both together though.
    Roslindale, MA
    Hmm... I don't want to split them... Will it still work well if you leave the tank lid open and just cover it with a bucket or whatever? Sorry for the stupid question...
  20. #70
    Lifer Trouble's Avatar
    Monkton, VT
    Yup. That's what I do with the Hawk carbs. I essentially roll them four times. It seems to work fine. I put the lid on as best as it can fit and cover the machine with an old cloth to keep the heat in a bit better.
    LRRS EX #7
    Low Down Racing
  21. #71
    Roslindale, MA
    Sweet, thanks. I'm picking one up. F YOU ETHANOL!
    Used mine today. Have a very old Norelco electric shaver. The shave head was quite dirty. Four minutes in Simple Green and water and everything came out looking like new. Works like a champ.
    still rocks...I cleaned the airbox cover on an XR100 and the carb before selling it
    gonna clean the 2CHAINZ that I wear around my neck BEFORE HITTIN DA CLUB
    I wonder how long I can leave a cleaning solution in there?
    doesn't seem to leak or anything
  24. #74
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    One tip for keeping your solution cleaner when cleaning nasty parts. Put some solution in a ziplock bag and put your parts in with it. Seal it up and drop it in the tank full of cleaner or water. The bag won't affect the cleaning and will keep the really nasty stuff out of your tank. This method works mint for keeping small parts from getting lost.
    5 Not allowed! Not allowed!
  25. #75
    Pigs water ignoring oil absorbing cloths are good for skimming crud out of the cleaning water too.
  1. Replies: 28
    Last Post: 04-19-20, 06:29 AM
  2. local ultrasonic cleaner
    By gamorg02 in forum Bike Maintenance
    Last Post: 01-23-13, 04:52 PM
