So I took the bike to work today, came home all was fine and dandy. I went food shopping and when I went back out to talk on the cell I see this.
Any one know how to fix this? Also because I'm bike maintence stupid what is this hose.
I called Derry Cycle as thats who I bought the bike from and they closed at 7 pm.
Wirelessly posted (Tilt: HTC-ST7377/1.59.502.3 (67150) Opera/9.50 (Windows NT 5.1; U; en))
those are overflows, and it should be stuck to your plastic on the left, its fine, zip tie it to the radiator hose
~Scott
2020 SMC-R
dont zip tie them tight. mine got unstuck so i put them on the lower radiator hose, its the bigger hose going into ur engine, make sure they arent kinked and point twords the ground
i drive a gixxah too, trust me im a doctor, and i stayed at a holiday inn last night, you can take your fairing off aswell, and you will see where it was stuck immediatly. There will be half of the sticky pad, or a clean square in the unclean underside of the bike.
Thanks guys. I appreciate it.
It's just the bike's pee pee.
Congratulations! It's a boy!
You're not Jewish, are you? OUCH!
Be a good thing to have secured before they pop off and goo your rear tire some fine day..
they are normally, pointed twords the rear tire :/Originally Posted by toocrazy2yoo
