Results 1 to 15 of 15
Wanted to get a Throttle Body Sync
    Jun 2012
    Westborough
    Wanted to get a throttle body sync on my 2007 FZ6. Didn't want to take it to the stealership wait a couple of weeks and drop $$ for nothing.
    I have some other small updates to make to the bike
    1)Install a G2 Throttle tamer
    2)Change spark plugs (gap'd per spec)
    Any one here set up to perform these for a fees? I am in Westborough, MA
    Member THE STUFF 187's Avatar
    SWANSEA MA
    Re: Wanted to get a Throttle Body Sync
    That is all small stuff we could take care of it for you within a day or two
    Adrenaline Cycle
    Swansea,MA
    Dyno Jet Tuning Center
    Apparel
    Fabrication
    Powder Coating
    Paint
    Service
    Engine service
    Race Bike Prep
    Used OEM Parts
    Track bike rentals
    ADRENALINECYCLEINC.COM
    Like us on Facebook
    [IMG]http://www.facebook.com/AdrenalineCycle1?ref=hl
    Wirelessly posted
    You dont gap spark plugs any more grandpa. :-)
    I don't know what a G2 throttle tamer are, but...
    1.) the carbs you can sync yourself with a service manual, youtube, and borrow the sync tool from anyone else that bought it for $120, used it once, and don't use it.
    it's a little more work, so if you outsource it - TLRman
    2.) spark plugs - also you can do yourself with a service manual. I don't know about your bike specifically, but it pretty much just requires you to take off the tank/covers, get a deep socket (or a spark plug wrench with an extension), and unscrew the old one install the new one. Sometimes it helps to get a pivoting extension so you can take it out from an angle, but that's it
    and do you really need plugs? I've got 30,000 miles on a used bike and never changed the plugs as long as it's burning right
    Jun 2012
    Westborough
    Wirelessly posted
    I am completely machine illiterate. Most of my information comes from forums such as these. The FZ6-forum folks recommended I have the spark plugs regapped to spec.
    Wirelessly posted
    Quote Originally Posted by Karate.Snoopy
    Wirelessly posted
    Ah. I see. No need to hap plugs any more except for maybe your lawn mower. In fact, if you try to measure the gap on an iridium plug, youll probably damage it.
    Does his bike ship with iridium plugs? Mine didn't. Suzuki's recommended swapping the factory plugs at 7500 miles on my 'strom...
    Wirelessly posted
    No, his doesnt. Just saying youll damage them if you try, bit plugs are pre-gapped always now.
    Apr 2011
    Rockland
    I was thinking of syncing my fz6 as well, some say it helps with vibrations and not just making the bike run better. I was also going to make my own sync tool since it is not that hard and much cheaper than buying an expensive tools, unless someone has one for rent
    Keep it Kosher rsw81's Avatar
    Boston, MA
    I have the sync tool, but no longer own a bike that requires one. Willing to part with it for $50 if you want it. Bought it new, used it a few times, definitely smooths out the throttle response and quells the vibrations the FZ6 gets at 4-5k rpm.
    --Rob
    Lifer golden chicken's Avatar
    Attleboro, MA
    Precious metal-tipped spark plugs like Platinum and Iridium-tipped ones should come pre-gapped. Attempting to alter the gap may damage/destroy the precious metal tip. Regular plain copper core plugs should be gapped for optimum performance, although I've seen cars run with gaps double the spec. High compression/high rpm engines could be more sensitive to large/wrong gap.
    SWANSEA MA
    We use a vuccum mate electronic sync with rpm pick up that is far more accurate then the other methods
    Adrenaline Cycle
    Swansea,MA
    Apparel
    Fabrication
    Powder Coating
    Paint
    Service
    Engine service
    Race Bike Prep
    Used OEM Parts
    Track bike rentals
    Like us on Facebook
    Apr 2011
    Rockland
    Quote Originally Posted by rsw81 View Post
    --Rob
    it was nice to meet you Rob and thank you
    Apr 2011
    Rockland
    ended up syncing my TBs last night and went from this
    Wanted to get a Throttle Body Sync-beforesync-jpg
    to this
    Wanted to get a Throttle Body Sync-aftersync-jpg
    in about 20-30 minutes, took a short ride and vibrations and buzzing are mostly gone.
    Boston, MA
    Quote Originally Posted by 7UPyours View Post
    to this
    solid work man!
  1. Anyone have a throttle body sync tool?
    By stanga5o in forum Bike Maintenance
    Last Post: 01-21-14, 09:06 AM
  2. Anyone Have A Carb Sync Tool/Knowledge To Perform A Sync?
    By WordTooYoMamma in forum General Bike Related
    Last Post: 05-29-12, 06:13 AM
  3. Balance/Sync Throttle Bodies, local place?
    By 03Worc9R in forum Bike Maintenance
    Last Post: 05-05-11, 10:17 AM
  4. throttle body and valve check
    By Wayne-o in forum Bike Maintenance
    Last Post: 03-11-04, 05:45 PM
  5. Throttle Body Synchronization
    By hohum in forum Bike Maintenance
    Last Post: 06-27-03, 02:24 PM
