Results 26 to 50 of 67
Winter Riding Basics
    Re: Winter Riding Basics
    more stroke usually equals more torque.
    oversquare is when the bore is larger than the stroke. shorter strokes generally produce more horsepower and allow for a higher RPM.
    Quote Originally Posted by z3dsp33d View Post
    I don't know, what oil do you use in January?
    I use the same oil as the temperature.
    10w-30 covers the temperature range for 10 degrees to 30 degrees right????
    Member z3dsp33d's Avatar
    Oct 2013
    Amesbury, MA
    2 + 2 is also 5.
    Let me edit the OP:
    1. If there's salt on the roads... park the bike.
    2. If the roads are wet in the morning and you commute home at night... park the bike.
    3. If it's snowing... park the bike.
    4. If it's below 45*... park the bike.
    That's about all you need to know...
    The key thing I concern myself with winter riding is:
    - Will I need to tear down my bike to the frame each time I ride it to get all the salt/calcium off the exhaust/motor/swingarm/wheels/chain, etc...
    Quote Originally Posted by Danny500 View Post
    Let me edit the OP:
    that sounds more like winter parking advice
    prepared correctly, you can ride in any conditions that you can drive in
    Dec 2011
    Marlboro
    Following up on Randy's advice:
    You're not going to really know if you're prepared until you try.
    When you're trying things, take baby steps on short rides near home where you don't have to be anywhere.
    Pass this on to 6 people and your crush will call you within 3 hours.
    Break the chain and the ghost spirit of an old lady will cause you a flat tire while you are doing 70 on the highway
    So in the summer you use..?
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    I convert to metric for summer temperatures.
    Well played!
    Lifer Not Sure's Avatar
    NH Seacoast
    I love a good winter fair.
    If my memory serves me right, I believe it has something to do with displacement and the ratio of bore and stroke. I could be be wrong. Having a larger bore comparative to relative stoke can produce more torque while having a larger stroke comparative to relative bore can produce more horsepower..
    Oh yeah, you really know your way around an engine!
    Get some Boeshield. Works great. If I could just remember to apply it each Fall....
    RandyO, you'd inquired at one point about additional battery capacity for cold starts. Check out the Lithium jump start battery from Antigravity - weighs less than a pound so you could keep it under your gear to keep it warm.
    http://antigravitybatteries.com/microstartxp1/
    T9 is the SHIT.
    WOW pretty impressive.
    Check it out.
    Westford, MA
    Winter riding is awesome. A lot of snobs on here are afraid of getting a little bit of salt on their precious Ducatis.
    Although I would recommend getting a chain oiler as the salt can wreak havoc on your chain. I have the Tutoro-auto unit fitted on my bike. No electrical or vacuum hookup, instead uses a brass weight that bounce up and down with the vibration from the road. It's beautifully simple and quite effective.
    ...I have your pants!!!
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Quote Originally Posted by Rossco View Post
    Do they make belt oilers???
    Posted by Jane in BoxChat
    sure they do. you fill them with Armorall.
    those jumper clamp wires don't look up to the task of handling the amperage they claim is available for jump start, I've seen heavier gauge melt
  21. #46
    Durham
    It's all about heat and heat is the result of amps over time. A pack that small can't possible produce 2-400 amps for any significant continuous time so heat buildup would be minimal. However, I agree that what appears to be 10ga. wire is awfully thin for that kind of current load.
    Wow, I thought you'd complain about the price per pound first!
  23. #48
    I don't see it as a winter survival tool, but a good backup plan for having your charging system fail on Tripoli Road 100 miles from home, something like that and unplugging the headlights woulda got me home
    I would not attempt to jump start any vehicle in frigid cold with cables less than 4 AWG preferably 2 AWG,
  24. #49
    Oct 2013
    Amesbury, MA
    Find some friends and a small hill. Give er the old push and pop and she will roar right up!
    Mar 2012
    Chichester, NH
    Give that a try on a snow covered hill.
    Regardless of how many friends might be around or how small your hill is, that pop part might not work out as easily as you expect.
  1. Ice Riding Basics
    By Ken C in forum General Bike Related
    Last Post: 02-02-15, 08:53 PM
  2. Ice riding winter 2012-2013
    By RandyO in forum Dirty Bastards
    Last Post: 02-24-13, 09:04 AM
  3. Basics of Motorcycle Riding - Informative Speech
    By ninjachica250 in forum General Bike Related
    Last Post: 02-17-11, 12:40 PM
  4. Winter coming ICE RIDING
    By KB in forum Dirty Bastards
    Last Post: 03-10-09, 02:30 PM
  5. This would be fun for riding in the winter!
    Last Post: 11-21-05, 01:02 AM
