Results 1 to 11 of 11
How to wire motorcycle for GPS?
    Portsmouth, NH
    Hey y'all, I'd like to use my Garmin Quest GPS unit on my motorcycle. It fits perfectly in the top of my tank bag, but the battery life of the unit is measured in minutes, so I need to wire it. I can modify the cradle so that it fits the tank bag, but the cradle needs 12V cigarette lighter power.
    Any recommendations on how to wire it? I'd prefer some sort of waterproof quick connect.
    Thanks,
    atek3
    Portsmouth, NH
    Re: How to wire motorcycle for GPS?
    something like this seems good:
    All-Weather Power Outlet (Standard Adapter Plug) :: Electrical Accessories :: Electrical :: Prevent Or Repair :: Aerostich/RiderWearHouse Motorcycle Jackets, Suits, Clothing, & Gear
    would it be okay to wire that underneath the fuel tank between the two cylinders? My concern stems from the heat, it probably gets about 200F in between the cylinders.
    thanks,
    atek3
    Apr 2006
    Beverly, MA
    If you know you're not going to get it wet, or all the pieces (GPS, power wire, etc) are waterproof you could install an all-weather connector like you posted above. Then you can clip off the cigarette lighter part and wire in a powerlet connector.
    I would not trust a standard cigarette lighter plug unless you install it in the tail of your bike. That's what I did on my SV and it's been fine so far.
    Feb 2008
    Devon/Surrey, England
    I'm pretty certain there are dedicated handlebar/RAM mounts avalible for the Quest - Cycoactive have at least one plus a hardwire kit :
    RAM Handlebar Mount for Garmin Quest & Quest 2 by CycoActive
    I have an old 2610 for the bike - RAM mount and hardwired to the battery - pretty easy to install, and waterproof. I'm sure you could do the same with the quest.
    As an alternative, you could look at the powered-tankbag option, - a little more expensive/complex (Bags-Connection do a quick release electrical tankbag mount, if you want to go that route. Twisted Throttle carries their stuff)
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Quote Originally Posted by MVOUS View Post
    wow...ipods and gps on the motorcycle. Whats next a coffee maker?
    Air Conditioning!
    2008 Honda CBR 600RR
    Lifer markbvt's Avatar
    Georgia, VT
    Quote Originally Posted by akira700 View Post
    Air Conditioning!
    I think Goldwings are actually available with air conditioning.
    As for the original poster's question -- yeah, what the folks above have said. Just install an accessory power outlet to plug your GPS into. Depending on what kind of bike you have, there may be a factory accessory outlet plug that clips into a pre-wired connector on the wiring harness (my Triumph has this), or you may need to just wire your own (as on my Suzuki) -- you can either run it straight off the battery, or install a relay so the accessory power turns on/off with the ignition switch. The advantage of not using the relay is that the plug works in both directions, so for winter battery maintenance you can just plug your battery tender right into the outlet socket.
    --mark
    Portsmouth, NH
    so do you think the engine heat will be a problem?
    atek3
    Georgia, VT
    I wouldn't put it between the cylinders. Just run wires from your battery and install the outlet somewhere in the cockpit area.
    --mark
    The Fastest Indian! kamikaze's Avatar
    Jul 2008
    Delhi, Indiaaahh!
    and Air Bags now!
    Sold: 1999 Kawasaki ZX-7R
    2005 Pulsar 180 DTSi
    Owning: Pulsar 220 DTSi
    http://www.dhairyagupta.com
    http://bostonbiker.blogspot.com
    Portsmouth, NH
    I know it's ghetto, but now I can use my GPS unit on my motorcycle. Sweet. (yes I realize it's not all weather)
    atek3
    Lifer Jayspeed's Avatar
    Medford, MA.
    Jay
    2013 gixxer 750
    2009 Ducati M1100s
    2017 KTM exc-f 350
  1. Wheelie-Wire?
    By toocrazy2yoo in forum General Bike Related
    Last Post: 07-12-09, 08:24 PM
  2. Safty Wire
    By hammadown in forum Pit Area
    Last Post: 04-27-08, 11:15 AM
  3. safety wire?
    By Awesome in forum Pit Area
    Last Post: 03-23-05, 05:04 PM
