Page 8 of 15 FirstFirst 123456789101112131415 LastLast
Results 176 to 200 of 357
100 Days
  1. #176
    Nov 2007
    Re: 100 Days
    Quote Originally Posted by PPS26 View Post
    what are thinkin for motor options??
    I already have all the parts to rebuild it... new cylinder and crank and bearings and rod, 12.5 JE piston, head is already lightly ported and will be beefed up with kibblewhite stainless valves and springs, maybe relap the seats.
    it had a wiseco 13.0 in there, i looked at JE (since theyre actually the company that makes the factory connection pistons just not marked up to stupid prices) and they had 12.5 and 13.5 so I figured I would go on the conservative side since I think the high comp is what did her in along with lots of hours
    Zip-Tie Alley Racing
    LRRS/CCS #103
  2. #177
    Re: 100 Days
    New valves means have the seats cut and lapped to match. On the piston, the more cam overlap you have, the more static compression you need... what's in there now for a cam?
    Registered Boozer PPS26's Avatar
    May 2007
    haverhill ma
    Re: 100 Days
    Quote Originally Posted by ceo and a bunch of numbers View Post
    I think what your doing sounds real good, conservative on a 450 is always good, crazy mods from what i see =trouble and more cash haha... cant wait to get back up there the excitement is building here at the shop
    Plaistow Powersports Racing
    Lrrs/ccs/ahrma EX #26
  4. #179
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: 100 Days
    I can't wait to get somewhere, where the excitement is building !
    Posted by Jane in BoxChat
  5. #180
    Nov 2007
    Re: 100 Days
    yeah I'll have to find somewhere around here to have that done. So I should just take the valves and the stripped head to this shop once I identify it?
    Cam is stock.
    Yeah I've seen that as well. Mine was fairly mild but I put a lot of hours on it I guess. This one will be the same but a beefier head setup and a little bit less compression, I will probably still run C12 in it
    LRRS/CCS #103
  6. #181
    Re: 100 Days
    Sounds like a good plan. Shouldn't take long to cut new seats and lap the valves in if they know what they're doing. May want to give them the springs and retainers too so once the valves are mated to the head they can install them, if not have them mark the head and valves with a sharpie so they don't get swapped around when you do the install.
    Nov 2007
    Re: 100 Days
    Hmm ok. You mean mark to make sure left and right intake don't get confused or something? Because the intake and exhaust are different sizes so easy to know.
    Any idea how much the cut and lap should cost? And any suggestions for a place?
    LRRS/CCS #103
  8. #183
    Re: 100 Days
    Right, no point cutting and lapping the intakes properly if you swap'em when you install. As far as where to go, the only place I have hands on experience with is in southern Maine, which I'm guessing is a bit far for a valve job. Gotta be someone closer to you who's on the ball for this sort of thing.
    Nov 2007
    Re: 100 Days
    $$ estimate for that type of work though?
    LRRS/CCS #103
  10. #185
    Re: 100 Days
    I've no idea on that one. 1 to 3 hours labor, depending on how good a job they do?
    Re: 100 Days
    CEO, I have a couple resources for you if you need.
    CCS/LRRS #83
  12. #187
    Ahh why not! lrrs428's Avatar
    Oct 2007
    Littleton NH
    Re: 100 Days
    there is a place in Keene NH i think, bought a crf head off him. he lapped the valves on a used one and installed the valve's and springs. total for the head lap, and valve set up was less than 400 shipped to my door. I have to find his card but i think he was called Vandis Machine? he does work for Shane and nate poole, dont know if that helps. other than that McMasters in maine is who my mechanic uses. McMasters used to build nascar motors for him. Quint Boisvert (my mechanic/Sponsor) had a motor done by pro-circuit and sent it to McMasters because he wasn't happy the the job they did. so he is pretty good. but turn around can be slow.
  13. #188
    Oct 2007
    Littleton NH
    Re: 100 Days
    30 Days
    Nov 2007
    Re: 100 Days
    Yes sir, I forgot to ask you about this last night...
    Quote Originally Posted by lrrs428 View Post
    That includes the parts? So what maybe like 125 bucks for cut and lap?
    I'll have to look into this.
    LRRS/CCS #103
  15. #190
    Oct 2007
    Littleton NH
    Re: 100 Days
    ya that included the parts
    Oct 2007
    Littleton NH
    Re: 100 Days
    29 Days wow
    Oct 2007
    Littleton NH
    Re: 100 Days
    28 Days
    Re: 100 Days
    I would look at Harrys Machined Parts in Northborough, MA.
    (508) 366-1455
    No idea on cost but the guy has a pretty good reputation as a japanese motorcycle race engine builder.
    Oct 2007
    Littleton NH
    Re: 100 Days
    27 Days
    Oct 2007
    Littleton NH
    Re: 100 Days
    26 Days and man do I need it, if I get anymore bad news im going to flip
    Lifer lrrs313's Avatar
    Asheville, NC
    Re: 100 Days
    What happened?
    -Brian
    15 S-Works Venge
  22. #197
    Oct 2007
    Littleton NH
    Re: 100 Days
    25 Days
    Just Registered Doc's Avatar
    Jericho, VT
    Re: 100 Days
    New subframe mounted, hope to get my motor this weekend...
  24. #199
    Oct 2007
    Littleton NH
    Re: 100 Days
    get it all freshend up?
    Jericho, VT
    Re: 100 Days
    New Heads, ported and polished (8-10hp). Had the flywheel removed while I was at it. (less weight and it will spin up quicker). Hoping to go from 63 to 70 something HP
    I need all the help I can get since I bumped.
  1. Great days at NYST with Tony's Track Days
    By davemon in forum General Bike Related
    Last Post: 08-26-13, 01:27 PM
  2. 3 days and counting.. my first track days
    By Lxpony in forum General Track Day Talk
    Last Post: 06-27-10, 11:16 PM
