Results 1 to 12 of 12
Stupid anti-freeze question
    WMC original sdog30's Avatar
    Burgy
    You guys just drain the water out of your race bike for the winter or do you add anti-freeze, too?
    LRRS/CCS #66
    Jan 2009
    Waltham
    Re: Stupid anti-freeze question
    I know nothing about race bikes, but I assume the anti corrosion of the antifreeze would make it worth more than leaving it empty?
    Apr 2011
    NH
    I and anti freeze then run the engine to circulate it. Could be over kill but what the hell. In addition to the anti corrosion it lubes the water pump seal.
    Tim
    LRRS #44
    Superbike Services 44
    drain, add coolant, and run it to circulate the coolant through the block
    Feb 2007
    I actually fill it with antifreeze for all its non corrosive properties. You gotta drain & flush it first thing in spring though. Why roll dice with corrosion?
    Thanks for the reminder... probably take care of that today.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    and I just buy the cheap stuff that says safe for aluminum and can mix with any color. not point wasting the money at the dealer since its just gonna be drained in the spring and never really used.
    Senior Member Slowpoke387's Avatar
    Enfield, CT
    Anti freeze every winter. Drain it in the spring and use it again next winter if it's clean which it should be.
    LRRS #387
    You save coolant to use it again next year?
    Enfield, CT
    I do ya. Havent had any issues yet. Bike basically sits all winter so i figure why not. Usually just check it after draining, keep it in a clean jug. I don't think it goes bad, lol.
    LRRS #387
    i just toss the $10 worth of anti-freeze and put new stuff back in next year
    Enfield, CT
    I'm too lazy to go to the store. That would interfere with my nap, sucks getting old...lol.
    LRRS #387
  1. Stupid question
    By Jewcati in forum Bike Maintenance
    Last Post: 04-11-14, 08:21 AM
  2. stupid question
    By 636 in forum General Bike Related
    Last Post: 09-23-07, 01:55 PM
  3. Aged anti freeze???
    Last Post: 03-30-07, 10:33 PM
  4. why is anti-freeze
    Last Post: 11-19-02, 07:34 PM
