Results 1 to 15 of 15
Bike Prep
    something witty here tsanterre's Avatar
    Milton, VT
    Bike Prep
    SO...
    Last year was my first year of racing... meaning this is the first time I'll be pulling my race-bike out of storage to get it ready for the up-coming season!
    Anything I need to do to the bike other than the normal prep work of taking a bike out of storage?
    I mean, I've read other threads / forums, I know basically what to look for / what to do.. but I want to make sure I'm not over-looking anything since it will be my first time coming out of winter and going to the track.
    Anybody made themselves a little check-list that I could steal?
    TIA
    ~that which doth not kill me can only make me stronger~
    LRRS / CCS - #103
    Re: Bike Prep
    Step 1 - look at bike
    Step 2 - kick tires
    Step 3 - start bike
    Step 4 - ride bike
    Steps 5 through 1,322 - wish you had gone through the entire thing to check torque specs on all the important bits.
    Milton, VT
    Re: Bike Prep
    word homie.
    Steps 1 - 4 - done.
    I do have shop manual with all the torque specs... i check that sucker often.
    ANYWAY...anyone else with useful input?
    LRRS / CCS - #103
    Re: Bike Prep
    Eff yoo! That was useful!
    Seriously though... just go through the bike & see what it needs.
    Change oil if needed
    Change filters if needed
    Change spark plugs if needed
    Blah blah blah
    Feb 2009
    Lost in constant migration
    Re: Bike Prep
    Step 2 - kick tires
    Step 3 - start bike
    Step 4 - ride bike
    This is all I did last year. This year I plan to also change a bunch of crap I wanted to change last year and never got around to.
    Every bike is different. I ride an EX. The only "prep" I NEED to do is
    1) remove family of mice from airbox
    2) put front wheel & tire back on
    3) ride bike
    Milton, VT
    Re: Bike Prep
    what about suspension?
    LRRS / CCS - #103
    Feb 2009
    Re: Bike Prep
    I'm told you should at the least do your fork oil every season, and if you're legit fast just send your shit to Kates every spring. I've done my fork oil exactly once, ever, and it was toward the end of last season. I'll probably do it again opening weekend.
    Re: Bike Prep
    Quote Originally Posted by tsanterre View Post
    I thought you were just pulling it out of storage & running as is
    This winter I...
    Rebuilt my motor
    Rebuilt my suspension
    Completely disassembled the bike down to a frame, swingarm & wiring harness
    Checked wheel bearings
    Checked swingarm pivot
    Repairing & repainting bodywork
    New brake master cylinder
    New brake lines
    New lightweight battery
    All new fluids
    etc etc etc.
    Feb 2009
    Re: Bike Prep
    This winter I...
    (Paid my motor guy to) Rebuilt my motor
    (Paid Kates to) Rebuilt my suspension
    New brake lines
    All new fluids
    etc etc etc.
    fixxored
    Not that there's anything wrong with that, mind you. At your level buy the best shit you can, I'm sick of watching you podium without winning and god knows those 2 LW aliens in front of you don't do all their shit themselves.
    Milton, VT
    Re: Bike Prep
    That was my question... can I just pull it out of storage and run it as is? Would that be safe? Would that be harmful to the bike?
    I'm def. not legit fast.
    The things you mentioned seemed more like upgrades then routine maintenance.
    I'm looking for more NEEDS than WANTS. I understand you can never be too cautious.. just trying to make sure I nail down the stuff that is going to keep the bike safe and me safe.
    LRRS / CCS - #103
    Re: Bike Prep
    change fluids if necessary, torque important shit if necessary and ride
    It's not like bike's magically turn into death traps over the winter
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Re: Bike Prep
    Yea I always just changed all fluids, double checked the brakes (fluid and pads), and gave the bike a really solid cleaning and once over. Pretty much stuff I'd check any given race weekend anyway.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Re: Bike Prep
    Drain antifreeze and add water wetter
    Member STREET&COMP's Avatar
    May 2010
    Troy, New York
    Re: Bike Prep
    Not to be an ass but the best post storage prep is pre storage prep, change your fluids before you put the bike in storage, treat the gas and fill the tank, or if you have good storage that is climate controlled and the temp doesn't vary too much drain it completely. Disconnect the battery, and throw it on a GOOD tender. Check the tires and psi, check the chain and give give it a good lube, check forks and fork seals, brake lines, pads, master cylinder. Double check all nuts and bolts that are attached to something that moves, pinch bolts, carrier nuts, swing arm, axles, steering stem, calipers. For the motor if you can touch the bolt check it, they make small wrenches, if it feels loose with a wrench check the torque. That's just a quick run down on what I do to my bike before I store it, I mean odds are it's the last time I'm gonna touch it for months and I need spend as much time with it as I can.
    Feb 2009
    Re: Bike Prep
    I forgot this one because I don't plan on doing it until I get to the track (mine is stored in an unheated shed) but definitely a really good thing not to forget!
  1. Various track day promotors... Bike prep?
    By GixerJockey in forum General Track Day Talk
    Last Post: 07-24-08, 09:30 PM
  2. Example pics for bike prep
    By Kurlon in forum Pit Area
    Last Post: 09-22-07, 06:39 PM
  3. race bike prep...
    By oreo_n2 in forum Pit Area
    Last Post: 04-23-07, 04:25 PM
  4. Cornerspeed's Bike Prep Rules...
    By highsider in forum General Track Day Talk
    Last Post: 04-02-07, 10:54 PM
  5. race bike prep/ day 1
    By GMS1000 in forum Pit Area
    Last Post: 01-31-03, 09:55 PM
