I am looking to buy new brake pads for my Motard and figured I would ask for opinions on what has worked for others in the past.
The bike: 06 Husqvarna SM510R
The brakes: Brembo four piston four pad radial mounted calipers
Looking at EBC's site they reccomend the FA322. Ferodo FDB2120 or FDB2215 or FDB2255.
Any suggestions?
Thanks
Joel
Vesrah RJL
Pete
loved vesrah pads on the hawk. don't remember which ones i used though.
Scott
I think I ran Ferodos the last time I changed them on my ktm with the Brembo caliper. Remember that you don't want too much initial bite on the tard. You can end up slowing down too much.
-Brian
15 S-Works Venge
I've used virtually nothing but EBC HH's for the last few years... Made the switch to Vesrah RJL's (they dont make the SRJL for my calipers) and I dig em. A little more bite and a little more stopping power. They seem to be lasting quite well, too. Seems to be what the majority of SV guys use.
Once these wear out I might consider going over to Carbone Lorraine if they've got anything that fits.
Here is the question when it comes to pads. How do you like to brake? Brake late with high initial bite or trail brake with a linear compound. Then what rotors do you have? And finally how much do you want to spend? You have Metal Sintered and Carbon Lorraine/Carbon Metallic/Organic. Most pad companies make both, some only make one. Carbon pads are softer on rotors and need less heat for the compound to do what it has to (ie: initial bite, linear). Sintered pads are harsh on rotors and tend to need a lot of heat on the compound to get working which in return = more chance of fade. It is all preference and what works best for your set up. Odds are an organic pad is going to work best for the Tard, not as heavy of a bike and they offer more control when braking. Vesrah RJLs might be a little over kill on that thing. You need any more info or compare certain pads and compounds let me know.
First off, thank you to all of you that have responded. Not that it cleared up my situation any but I do appreciate the replies and knowledge.
Oddly enough I would say a combination of the two is what I try to do. I try to brake late and then trail it off into the corner
I have the stock Brembo 320mm semi floating rotors. I say semi floating because there is a dab of some type of epoxy or glue of some sort on the buttons from Husqvarna ( I assume to keep the noise down on their "street" bikes )
Not too much of an issue as this is my race bike and I really like to be able to slow down when I have to. Hopefully they will last a while as well.
I am not certain what is on the bike stock but the sintered pads have worked well for me on my street bike. If you have any part numbers and prices for the Sintered and Carbon options that may be helpful as well.
Thanks for the detailed reply!
Joel
so does all this mean the huskey is returning?![]()
Scott
Usually a card covers one caliper.
