Page 1 of 4 1234 LastLast
Results 1 to 25 of 96
Drain coolant for winter
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    so there will be no thread about thawing a engine and is it junk? A fresh charge on the transponder ain't a bad idea either.
    Wirelessly posted
    Good tip!
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: Drain coolant for winter
    you people are late. I did this about a week after the last round.
    I'm late, but my excuse is my bike is in my basement where it never drops below 50 degrees.
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Out of curiosity by a non racer wouldn't filling it with 50/50 regular coolant be better than empty? I would worry that there was some water retained that could freeze and cause a crack in the radiator fins unless you blowing out the system with a compressor.
    Bridgewater, MA
    I always fill with coolant for that exact reason. then flush it out in the spring.
    WMC original sdog30's Avatar
    Burgy
    All set.
    LRRS/CCS #66
    FZR has got fresh fluids in the sump and radiator, carb's drained via bowl removal so I know they're dry, and it's snug in the basement on stands for the winter, never to see temps below 60 degrees.
    My motor is going to be vacationing in Alabama for the winter.
    Quote Originally Posted by slammp View Post
    Yes and to stop any corosion.
    something witty here tsanterre's Avatar
    Milton, VT
    Isnt engine ice (or one of them) good to like -20F ?
    ~that which doth not kill me can only make me stronger~
    LRRS / CCS - #103
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    Quote Originally Posted by tsanterre View Post
    Yeah, Engine Ice prevents freeze-up to -26 F. I guess the time I just spent replacing it was wasted.
    Thanks for mentioning it, I thought its freezing point was the same as water. I'll just run Engine Ice all the time starting next spring.
    Edit - Water Wetter is approved for track use, and it does NOT lower the freezing point of water. Is Engine Ice considered OK for the track?
    Yeah, I know that technically you can run anything, including coolant, at most track days.
    DanG
    - Blaise Pascal
    How come we don't use it in cars?
    Because it's expensive as shit.
    Less than 8.50 a bottle at Advance Auto Parts with a coupon code. How much water will one bottle treat? (I only use a tiny capful in the bike.)
    Are you talking about water wetter? Water wetter won't keep water from freezing.
    Yes thats what I checked...watter wetter
    Bridgewater, MA
    you can run it in your car if you want. nothing says you can't.
    Milton, VT
    Quote Originally Posted by oVTo View Post
    ... Is Engine Ice considered OK for the track? ...
    Yes, it is.
    LRRS / CCS - #103
    Its gonna be getting cold.
    Winchester, MA
    Only because you're paying for the brand. Engine Ice is just propylene glycol (a non toxic equivalent to ethylene glycol used as traditional antifreeze), which is also sold as RV& marine antifreeze. Available at walmart for 3 bucks.
    http://www.walmart.com/ip/Super-Tech...ype=10&veh=aff
    Christian has been very busy and hasn't come to the house to do all that for me on all my bikes hahaha
    Wouldn't hurt to throw a fresh charge on the transponder too
    Senior Member MarkMarine's Avatar
    May 2013
    Finally people are catching on to this. Btw, the claims they make about better cooling are BS. No coolant available has better cooling than water.
    Sep 2012
    Westford, MA
    Quote Originally Posted by MarkMarine View Post
    I was waiting for someone to say this.
  1. FZ6 Broke coolant drain bolt
    By Karate.Snoopy in forum General Bike Related
    Last Post: 06-19-13, 09:03 AM
  2. Replies: 4
    Last Post: 11-12-08, 02:52 PM
  3. VP C12 .... drain it or not?
    By derrickhackman in forum Pit Area
    Last Post: 05-24-07, 08:02 PM
  4. Coolant for winter....
    Last Post: 11-04-04, 01:13 PM
