Results 1 to 25 of 42
Interested in building a motard
    Senior Member netra709's Avatar
    Oct 2007
    I want to put together a bike to race the motard class. I have two bikes in the garage now, and its going to be one of them. I have got a 95 WXE610 husqvarna with about 12 original hours on it, and a 09 KX450F. I'm leaning towards the Husky because of the 6 speed gearbox,the bigger motor and the fact its too much bike for the woods. I could use the KX, but I have already dialed it in so well for the woods, I hate to undo the work I have already done. I also have a auto clutch in the KX, anyone ever run one on the race track?
    Any reason not to use the 610? It is technically almost the exact same as the TE570 they were selling in 2002. Thanks for any feedback, Tim
    Just Registered 13's Avatar
    Dec 2003
    Auburn, NH
    Re: Interested in building a motard
    I'm no motard guy, but I'd have to say the husky is probably not the better of the two for the track.....
    One of the former LRRS #13's
    http://www.facebook.com/ChrisWatt762
    JT42
    Quote Originally Posted by 7.62gigawatts View Post
    The KX450 for sure
    I can't find any specifications, but the mags from the era show it competing against the XR600, so I suspect it's going to be a porker compared to a modern 450. It'll likely do ok for Novice work, but you'll need something lighter by the time you get white and black number plates.
    Oct 2007
    Thats surprising, I thought it would have been a good candidate, but I don't know. Thats why I asked. Your right, its heavy, about 255-260lbs. Thanks Tim
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    The site is down tonight. But supermotojunkie.com is a good bet to get answers for that question. The Husky has a rather large piston. But a guy does race a Husqvarna 630SM RR at Loudon. If you do use the 610 you want to gear it high to take advantage of its massive torque and to keep the revs down. The KX450F is a Kawasaki ??? 4 stroke motocrosser??
    If it's 250lbs or less, hammer it!
    Oct 2007
    Yes, the KX is a mxer. I love the fuel injection on the KX, smoothest motor I have ever had. Tim
    Jun 2005
    Hands down the best way to get into a motard is to buy one already built.
    Converting a dirtbike isn't as easy (or as cheap) as it seems.
    That said, definitely the 450. You'd have a lot of trouble getting the '95 610 set up properly. Nobody's gonna have parts for it.
    Oct 2007
    Would I start as a novice, I didn't know if it would stir stuff up that I have raced offroad for 13yrs as a expert, but only have 3000 miles on the street under my belt. I wasn't sure where I would fit in.
    AMA wannabe lrrs699's Avatar
    RI,NH, Derby,ct
    if we are talking about the same guy...not anymore he blew the engine
    LRRS Expert #99
    08 R6
    "why tip-toe through life to arrive safely at death?" Tony Campol
    To quote PK, I "went in too hot and ran out of talent".
    Lifer Pittenger5's Avatar
    Austin
    Quote Originally Posted by lrrs699 View Post
    Yup, Brian 501 popped his engine
    Zip Tie Alley #505
    Quote Originally Posted by netra709 View Post
    Yes, you'd still start as a novice
    Oct 2007
    Cool. I miss the novice days.
    RI,NH, Derby,ct
    he is running a 900ss now
    LRRS Expert #99
    08 R6
    You could buy a nice Aprilia SXV, add a little safty wire and start the next race weekend...you can even have a race bike with a warranty for the rest of the season
    Brian has a 510. The guy I am talking about has a Limited Edition Eddie Seeles Replica. Blue and Yellow. This guy is a expert. BTW it is for sale.
    I agree. No matter what get all the brake you can afford.
    RI,NH, Derby,ct
    I guess we should let brian know about it....
    LRRS Expert #99
    08 R6
    Is that Graham's bike you're talking about?
    Brian is fast enough.
    RI,NH, Derby,ct
    or maybe we wont.....
    LRRS Expert #99
    08 R6
    Meriden, Ct
    That's what I was thinking too... 'Cause there can't be two of those things around.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    You'd be wasting your time making the WXE into a motard. Maybe it'd be a decent trackday toy but would get stomped as a competitive motard racebike at LRRS. Also the 6-speed gearbox isn't ideal, the 5-speed is mint at Loudon (coming from a guy that races a 4-speed) Too much shifting with the 6'er.
    The KXF450 is the way to go (or any other modern MX 450).
    Minimum items you need are:
    17" wheels - 3.25F and 5.0R
    Upgraded front brake rotor (preferable to add aftermarket caliper along with)
    Catchcans
    Barkbuster-style handguards
    Safety wire
    Come on out and join the fun Check www.twowheelsteals.com for some nice deals on parts. Calipers, rotors, etc.
    Boston --> San Diego
    Is there a noticeable difference on a tard between a 155/4.25 vs 165/5 setup?
