Results 1 to 20 of 20
CCS legal coolant or additive
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    I searched with no luck. Is there such a thing? I don't want to walk to cracked anything these next two weekends i the temps get under freezing over night. The Rulebook mentions a list of approved additives but I haven't seen one.
    LRRS 878 Clapped out Gixxah
    Wirelessly posted (GS3)
    I wouldn't worry about it. The temps won't be that low long enough to freeze the water in the system
    Re: CCS legal coolant or additive
    Water Weter or Maxima Cool-aide.
    Lifer Trouble's Avatar
    Monkton, VT
    Stick a lamp with an incandescent bulb under your bike if its going to get below 30 degrees. Otherwise you'll be fine.
    LRRS EX #7
    Low Down Racing
    Slightly OT. When do you guys drain the coolant. And do you replace it with antifreeze for the winter? Or just leave the machine dry?
    I drain the water after the last weekend is done. Then I replace with antifreeze for the winter and flush out well in the spring before use on track. Having antifreeze in there prevents corrosion and keeps pockets of water that still might be left from freezing.
    5 Not allowed! Not allowed!
    Prestone or whatever from autozone is good 'nuf for storage purposes?
    Monkton, VT
    Get yourself a heated garage. You know you were just looking for an excuse to get one anyway...
    LRRS EX #7
    Low Down Racing
    Yeah get the cheap stuff.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Honda calls for ethylene glycol with silicate free corrosion inhibitors (as opposed to silicate corrosion inhibitors).
    Honda claims silicate corrosion inhibitors can cause premature wear and failure to water pump seals.
    You can pick this up at your local autoparts store.
    Mine gets drained at the end of the season, filled with ProCool ('cause I'm lazy and it's premixed and readily available) then stored in my basement that never dips below 57 deg in the winter.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    I've been using the regular Prestone for a few years now without any problem. if you're just using it for winter storage and draining it in the spring I wouldn't worry. water pump seals can't be that tough to change even if you do need to. if you're really worried just find one labeled ethylene glycol instead of propylene glycol. Prestone Low Tox and Heavy Duty look to both be ethylene
    Sounds like I'll just pick up a gal or two of this ethylene glycol stuff and flush and refill the street bike as well while I'm at it.
    Wirelessly posted
    Drain and replace with coolant and RUN THE ENGINE until the t-stat opens. The important stuff to drain is in the head and wont drain while cold. The new coolant will mix with the water in the head once the tstat opens.
    How can you tell when the t-stat opens? Especially on a gauge-less track toy?
    Mar 2012
    Chichester, NH
    Leave the radiator cap off. You'll be able to see the difference.
    Prestone Low tox is propylene glycol, same thing found in many food items. Most other auto coolants and brake fluid are ethylene glycol = poison. I've seen that extended life, heavy duty, Dex-cool(orange), and "add to anything" coolants are silicate free. Silicate might wipe your pump seal if you put 100K on it. Definitely OK for winter storage! Thanks for the water reminder, first frost here last week.
    Bridgewater, MA
    you are right about the low tox. my reading skills obviously suck
    Feb 2004
    This is the official list of LRRS approved additives. Be aware that there are additives on the CCS approved list that are not legal for LRRS, such as Engine Ice. They allow Propylene Glycol, we don't.
    Johnny B. (the other one) ®
    Feb 2004
    I think Richie's wife would jump in at this point to mention that she lost one of her cats to one of these alleged "Low Tox" coolants. Do not assume that any of this stuff is safe to ingest.
  1. Coolant
    By imstuner in forum Bike Maintenance
    Last Post: 05-09-14, 11:06 AM
  2. Coolant
    By j4eric in forum General Bike Related
    Last Post: 03-22-11, 08:32 AM
  3. Replies: 8
    Last Post: 01-14-11, 10:21 PM
  4. Replies: 44
    Last Post: 05-26-09, 09:18 AM
  5. Coolant
    By Manny in forum Bike Maintenance
    Last Post: 10-26-07, 04:03 PM
