Page 7 of 8 FirstFirst 12345678 LastLast
Results 151 to 175 of 180
CCS ROC Daytona 2013
  1. #151
    Re: CCS ROC Daytona 2013
    Based on an earlier discussion, you should be looking at the torque curve, not HP.
    No ur wrong its Hp.....If he did that he would be shifting at 11K. Bike still makes power up to 15-15.5ish
    If it was a LS6 BB chevy thats a differnt story as cars to bikes is.....Torgue isn't like in a car the HP is what does the real work
    Just look at this dyno sheet as an Example: you would be shifting at 7K if that was the case
    Based on that torque curve I wouldn't shift at 7k, even without knowing the gearing I'm going to be going back to a point with less torque shifting that early. 9k looks like a better candidate, maybe pushing past a touch if the gearbox would make you dip past 6k when you grab the next gear. That'll keep you in the meat of the torque, but you've got lots of overrev for when you need to skip a shift due to track layout. (Ok, we're talking about a Busa so it's all straight lines but still...)
    Rev to Peak HP and shift easy as that.......
    If you're that anal & wanna get crazy with it.... http://www.sportrider.com/tech/146_0402_art/
  5. #155
    Good find Pete. I'm curious what dyno shop would actually dyno your bike in all gears, instead of just 4th.
  6. #156
    Quote Originally Posted by Jimmy Faceplant View Post
    Most will if you ask them to.
    It's to bad I can't get my laptop to hook up with my Yosh ECU. I'm sure there's a way to set the shift light for each gear.
  8. #158
    You've only got a USB cable for that right, not a standard serial cable?
    If you know your gear ratios you don't need to. The output of the motor is the same in all gears. The reason they use 4th is because it's typically closest to 1:1 ratio.
  10. #160
    Correct
    So my shift points would vary with different sprockets too?
  11. #161
    No, changing sprockets would alter the MPH you'd be at when you shift, but not the RPM.
    According to that article, my GUESS is yes, but barely. Changing the final drive ratio would affect all gears "equally", but because it's by a percentage it may change it a little. You'd have to do the math.
  13. #163
    #331 CBR929RE's Avatar
    Bridgewater, MA
    or get a Honda where it builds power all the way to redline
    Not true.....all bikes make peak HP then fall off.....and as that article proves, its before the Redline on the Tach
    Care to put money on that?
    I've had more than one machine that hasn't peaked out before safe redline/limiter. All depends on the setup. (Had one machine that didn't peak TORQUE before reaching piston speeds that spelt disaster. Fun screamer.)
    (Had one machine that didn't peak TORQUE before reaching piston speeds that spelt disaster. Fun tractor.)
    fixd
  17. #167
    fixd
    15k RPM on a chinese crank, rod and cast piston. Shouldn't even have run it up that high but it just kept making power so... If I had a spare bottom end I would have finished it off on the dyno just to see where it'd let go, but it lives on now as a tractor in Doc's 70.
    (Had one machine that didn't peak TORQUE before reaching piston speeds that spelt disaster. Fun Chinese tractor.)
    fixd
  19. #169
    Hah.
    Bridgewater, MA
    I have dyno graphs for 2 different Hondas that show it is true. gsxrs just suck.
    my 600 graph looks like it hiccups at the very very top, like it hit the limiter there. that's the only time it goes down.
  21. #171
    no short shifting this time. Stock gearing was topping me out at 151 MPH, but the +1 rear sprocket would get me around 155. Practice was stock gearing, races I ran +1
  22. #172
    where is the 169MPH GPS identified you said you hit?
  23. #173
    That was in ASRA SportBike, and I only record in practices. I cant tuck my helmet behind the windscreen when the GoPro is there. I'll post up a screen shot of the QSTarz data if you really want to see the top speed from that race.
  24. #174
    Meriden, Ct
    I'm not sure what's being argued here...
    But: Jim is wrong (and fat), Piggy is right, Pete is handsome, and Josh is spouting loads of crap that's over everyone's head.
    Bridgewater, MA
    when you say +1 you're talking about the front sprocket right? for some reason it sounds like you're talking about the rear but that would give lower top speed
  1. For Sale - Motorcycles | 2013 triumuph daytona 675(R)
    By Johnpewpew in forum For Sale
    Last Post: 03-23-21, 12:13 PM
  2. For Sale - Motorcycles | 2013 Triumph Daytona ABS
    By RacerXnh10 in forum For Sale
    Last Post: 05-20-20, 02:18 PM
  3. For Sale - Parts & Tools | FS: 2013/2014 Daytona 675 Woodcraft Rearsets - GP Shift $250 firm.
    By JettaJayGLS in forum For Sale
    Last Post: 06-11-15, 08:58 AM
  4. For Sale - Parts & Tools | 2013-2014 Triumph Daytona 675 race body work
    By datnguyen24 in forum For Sale
    Last Post: 04-13-15, 03:57 PM
  5. Daytona 2013
    By backinthesaddle in forum Pit Area
    Last Post: 03-13-13, 10:16 AM
