Exactly, this is why I think it makes sense to pursue corner speed first. Once you are close to maxing that out, you go back to the beginning and figure out how to get IN the corner faster without giving away that speed, then find work on getting OUT fast.
I'm sure there are other ways to get there, but that was my process and it worked well for me.
I also saw a lot of "stupid fast" guys in my days. The Jesus comes to mind...
Thats why I corrected myself after rereading... its important to realize how much speed you can cary through a corner, then learn to get down to that speed later and back up from it sooner. But, its the second part where I personally tend to find the most gains because of what Pete explained. Thats what I was trying to get at.
Agreed.
It's also one of the safer ways to do it as that's the slowest part of the corner. Concenrating on entry and exit before mid-corner speed can be a more dangerous approach. Speeds are higher, and as Ryan said earlier, so is the skill required to do it safely and proficiently.
Plus it's just the natural approach... I think we've all seen riders that are new to the track practically rolling off at the start/finish line, yet getting or almost getting a knee down.
Word. I smelled what you were cookin.
Nope, it read correctly to me.
LRRS 878 Clapped out Gixxah
This is a question worth a lot more than a paragraph.....
#1) Traction. More grip=more speed. We all know this. Tires are one of the biggest factors....but there are many more. The biggest influence outside of your tires are your inputs on the bike (not just body position - which matters...how you squeeze the bars, where your pressure points on the bike are, weight distribution front/rear etc..), which can have a huge affect on grip. Two riders - same bike, same speed, same tires, same lean angle....one crashes and the other one doesn't. Has anyone ever seen this happen? ... I thought so.
90% of what happens out there is a result of rider inputs. This why some guys are able to go faster than others. The biggest limiting factor is what we do to the bike. The lessons on how to maximize grip with technique are endless....which is one reason racing is so addicting.
Methods. The first thing you need to do is to work towards maximum roll speed, as this affects everything. How can you figure out what the latest brake marker is if you have not established how fast you can roll through a corner?...this is putting the cart before the horse. Also, roll speed has a huge affect on how much you can roll on. The faster the bike is rolling, the more throttle input it can handle. So again, you need to get your roll speed up first in order to really establish what maximium roll on can be.
The trick is to couple maximizing roll, entrance and exit speed with smooth and effective body inputs that maximize grip and feedback. Doing everything as hard and and fast as you can without causing any rapid changes in tire load.... let the fun begin.
LRRS/CCS EX #29
434Racer Performance Parts / Motul / Sportbike Track Gear / Knox / Dyno Solutions / Tony's Track Days / MTAG Pirelli / Nexx Helmets / Woodcraft / GMD Computrack
Well here is my hand drag Pic....
LRRS EX 66
factoryeffex
So, that was really the root of what I was trying to understand. All things being equal in ideal conditions with "perfect" body position and inputs, at what point do you say: There, that's the fastest I can get through this corner given this particular line.
Currently, I picture: pegs 1mm off the ground, tires sliding, rider hung way off with only throttle input. Is that maximum roll speed?
That would do it, but you're not gonna get there before learning some, or most of the facets of cornering.
more likely you will be having awkward moments that prevent you from going any faster. Slips, slides, line control problems, etc. Then you have to back up and improve your entry until those moment go away at that speed. Then you raise the bar again til the awkward slips and slides come back and you start the process over.
It never really ends, but you do sort of arrive at a point where your roll speed prety much stabilizes. Then you are really focused at both entry and exit improvements.
Thanks for the input Eric, I *LOVE* these kinds of discussions. I need all the help I can get if I am ever going to see Pete past the 3rd lap :-p
LRRS/CCS EX #29
My issue was and still is when I have to make changes in the line that I am attemption to take during the corner. When I went down at the bowl it was because I was going a lot faster than the rider in front of me so when he cut into my line I pretty much paniced straightened the bike up and went on the brakes.
It might come with time but right now I have very hard time making changes on my direction while im leaned in a corner.
Another part of the track that I am having trouble with is T10. I just dont understand where my body is supposed to be and whats my lean angle. I had several people showing me what line to follow but I always seem to roll off the throttle when I hit the bump which moves weight and makes the bike even more unstable.
Thank you for this topic btw learning a lot from it.. is it spring yet to start putting some of those techniques in practice?
That's only going to get harder as you get faster in a technical sense, but knowing what is possible comes with just doing more laps.
In my experience, when it comes to T10 you want to roll off the throttle out of T9 just enough to make T10 then get back on it early (like in T3) so you're accelerating through the bumps. You've obviously noticed how rolling off loads the front end more, making the bumps more noticeable. Crank through, it makes for a smoother transition, not to mention thats the part of the bike that makes you go... y'know, faster and stuff![]()
Throw it in HARD and get on the gas before the transition. I'm not always knee down out of there, but I'm close to it. Continue rolling on the throttle over the transition and the humps. Weight the pegs and let the bike move around.
My laps aren't perfect, but search youtube for some of my newer race vids. I don't add music so it should be pretty easy to hear my motor.
Watch my rate of turn from 9 to 10 and listen to my throttle inputs.
Getting on the throttle is whats important, it sends the load to the rear suspension which lets the bike float over the bumps much smoother. If you roll off it loads the front, so when it hits the bumps it upsets the chassis more. Stay loose and weight your outside peg.
Other than that... what Pete said. The line through there isn't anything special, its just faster/smoother to at least have the throttle rolled on over those bumps and let the bike do its thing.
like this?
No, like this
I love breakin that one out
That's two old school pix in one day!![]()
This is a great read!! All I can add is my day of One on One instruction with Pete really helped me out on corner speed!
In T10 I agree that getting off the wall sharply and pointed toward T11 as soon as possible helps a bunch!
