Here's MY theory... I wanna see if you genius engineering types agree.
Take the RWHP of the bike and divide it by total (bike & rider) new weight after your diet and you'll get a HP/WT ratio.
Then multiply that number by the original weight and you get the RWHP that you would have had before the weight loss.
Follow?
So let's say your bike makes 100hp
You & your bike weigh 550lbs after a diet...
100hp / 550lbs = .181818 hp per pound.
Suppose we dropped 7lbs, so we originally weighed 557lbs...
Well that should mean, assuming we believe the 7lbs = 1hp rule, that we'd be making 101hp if we didn't lose weight, right?
.181818 x 557lbs = 101.27. So we really gained the equivalent of 1.27hp.
That sound reasonable?
Lose weight and go faster. Simple as that. No need for advanced mathematics to tell you how much faster you've gone, you'll know that you went faster because you've lost weight.
Alright... so then lets take the same rider, but put him on a bike that's just as heavy but half the HP & see what happens...
Now your bike makes 50hp
You & your bike still weigh 550lbs after a 7 lbdiet...
50hp / 550lbs = .09090 hp per pound.
.09090 x 557lbs = 50.636363. So we only gained the equivalent of .63hp
Interesting... so weight loss makes MORE of a difference if you're on a higher powered machine to begin with.
See that's what I always thought too... But interestingly enough it's a .0127% theoretical increase in hp for both bikes
HOWEVER...
50/557 = .089767 hp/wt ratio
50/550 = .090909 hp/wt ratio
Difference = .0011% hp/wt increase
100/557 = .179533 hp/wt ratio
100/550 = .181818 hp/wt ratio
Difference = .0022% hp/wt increase
So the more powerful bike nets DOUBLE the hp/wt ratio increase of the less powerful bike.
The best thing is that it will corner better. Better tire life too.
Go ahead Pete, eat the ice cream. You know you were gonna anyway. All this silly math to justify it, really?
LRRS/CCS AM 636
That seems entirely counterintuitive. I would expect weight reduction to be much more important and noticeable on a lower horsepower bike.
Location, location, location. If you have a beer gut the distribution of weight is closer to the track and therefor creates a lower center of gravity. Especially important on a technical track like Loudon. If you're a dork with a big head you have a higher center of gravity. Step away from the calculator Pete and pick up a beer. It'll make you go faster.
LRRS EX #7
Low Down Racing
I am glad I have a beer gut.But Pete and his big head are still faster.
Haha. I also thought this. The fact is that although it may not be as noticeable, the key to going fast on a slow bike is maintaining speed. Now even with maintaining speed there is still variation in your speed and you have to accelerate coming out of corners. That hp is more noticeable with the smaller bikes I would think because it is much harder to make up for lost ground.
Did that make any sense?![]()
I like Pi![]()
CCS LRRS #454
With a small bike you are also using max power a lot more than a more powerful bike
-Brian
15 S-Works Venge
Let me get this straight. I need to lose weight but drink more beer?
Okay, I'll try.
Wow, I've lost 70 lbs since the last time I rode. So I get 10 more hp this season? Awesome!
Just proves that the 50-70 lbs heavier I am than you isn't helping me.
Begs the question though. Doucette easily lost over 50lbs, but did it make him faster or just easier to go roughly the same speed?
By your math you have at least 7 HP on me based on weight alone![]()
Right. Kinda like saying a pipe/filter/jet kit give a 10% increase in power. Obviously a more powerful bike will get more power from that.Originally Posted by Honclfibr
Yeah, Fatty. Loose some weight! (I actually gotta trim down, too. Gettin outta shape & growin a gut)
I dunno about Doucette. His fastest LWSS lap in 2010 was a 1:15.875. I'm not sure what his best was back before the weight loss, but it'd be hard to say anyway with the track changes that have occurred since. I'm also not sure if he ever went all out for a full lap cuz with Babcock out of the picture for most of the year he didn't have much competition.
Smaller bike = smaller crankshaft and wheels = less rotating inertia means faster and better handling.
I don't think its a good idea for me to lose weight. if I did I'd probably get blown right off the bike.
here's what a 40lb weight difference can do. both of us on 929s. he only gets me on the brakes cause he's a better rider. YouTube - attemptedpass.mov
LRRS Am #331
Quit using your clutch for upshifts
