Page 17 of 18 FirstFirst ... 789101112131415161718 LastLast
Results 401 to 425 of 437
Eject System
  1. #401
    go faster cdovego's Avatar
    Weymouth
    Re: Eject System
    This is quite disturbing.
    Central Mass Powersports #123
  2. #402
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: Eject System
    Quote Originally Posted by Dove View Post
    It has the potential to reduce the effect of the safety system built in to my Suomys. Ask me at the track, conversation for another day/thread.
    (from the NHMS changes thread)
    I was just saying its not meant to add any extra safety in the event of an impact. its stated purpose is to help reduce injury after a crash during the removal of the helmet.
    talk it up here. maybe we can get Bergs all riled up again
    Re: Eject System
    Oh Jesus Christ, not this shit again.
  4. #404
    Weymouth
    Re: Eject System
    haha - If you look in your Suomy, behind the liner you'll notice deep channels that run through it. Those are not in most helmets. The channels allow the foam to expand in the event that you need to dissipate some g forces. Anything foreign near that environment has the potential to effect that system. Whether we're talking 1%, 10% or 50% - I don't know. The potential is there and the fact that this company doesn't even demo on a roadracing helmet that is SIGNIFICANTLY tighter around your head (to keep it planted at 160mph) well, let's just say...I'm really on the fence about this product.
  5. #405
    Re: Eject System
    Dove - Be careful. You are up against an army of koolaid gulpers when it comes to this topic.
    You've been warned.
    May 2010
    Somersworth, NH
    Re: Eject System
    You arent the only one guy... the EJECT argument has been going on for a few years now. I may be incorrect also but I do not believe that it has ever been used successfully at NHMS following a crash to get a riders helmet off. pretty sure the couple times its been tried it failed.
  7. #407
    Weymouth
    Re: Eject System
    You've been warned.
    It's cool, I typically don't do well with the kool-aid crowd wherever I go.
    The designer of Suomy's safety system explained it to me in Suomy's factory in Italy. I'm confident in my opinion.
    You might also be surprised to find out Suomy has a much softer exterior shell than most helmets...for good reason also.
    If I could pass tech without this eject system, I would.
  8. #408
    Re: Eject System
    Most of the time, the channels in the foam are to improve air circulation...
    Bridgewater, MA
    Re: Eject System
    I do love mine and switched to another brand for one season and 1 crash. all my other crashes have been in Suomy and I keep going back so I think that says something about how much I like them. the only part of the eject that would interfere with the channels is the tube. If the foam crushes into the channels that much where the tube stops it than I bet you're in the hospital unconscious at a minimum.
    that was my impression too but i can see the argument for the foam being pushed into them a little.
    May 2010
    Somersworth, NH
    Re: Eject System
    there was an argument that the sticky stuff on the EJECT that holds it and the hose in place would corrode the foam in the helmet. Also it was mentioned that the EJECT and its hose could create pressure/weak points that wouldnt allow the foam in the helmet to properly do its job of displacing impact force.
  11. #411
    Weymouth
    Re: Eject System
    Primary function is to allow room for expansion to shed g forces. Yes, they're a natural and logical place to drill a hole for air circulation.
  12. #412
    that guy darkduc7's Avatar
    Apr 2010
    Georgia, VT
    Re: Eject System
    My eject system was not used after my bad wreck last year, when I had suspected neck injuiries, a broken back, among other things.
    Guess I can just transfer it into my new helmet again.
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    2008 sikk mx 125 minimoto
  13. #413
    Re: Eject System
    Quote Originally Posted by darkduc7 View Post
    Well that's comforting to know!
    I still side with Burgs on this topic, then again rather than bitch about it and worry about my safety, I'd have the system in the helmet for tech, and remove it while racing
    Jan 2012
    Lowell
    Re: Eject System
    Can anyone give an example where eject was used successfully?
    Jul 2005
    Bennington, NH
    Re: Eject System
    It has been used successfully in a motorcycle crash at LRRS. It is not necessary in most cases, and the safety crew is very good at removing a helmet without it.
  16. #416
    Re: Eject System
    i think thats the key here. ive seen some gnarly crashes this year in SX (where they claim teh eject system is mandatory) and have yet to see it be used. admittedly they dont show everything on TV, but...
  17. #417
    Apr 2011
    NH
    Re: Eject System
    is there a count on how many times,if any, it has failed?
    Tim
    LRRS #44
    Superbike Services 44
  18. #418
    Re: Eject System
    If any?
    There are two failures documented on this forum alone.
    Apr 2011
    NH
    Re: Eject System
    Burgs we're basically on the same side here. I remember those as, 'yea that guy' or 'I heard' not names but maybe I just don't remember.
    I think names/numbers or a count from a first hand would be more interesting/meaningful. I would also guess that corner workers/safe crew would not be able to say if one did fail but that's the conspiracy in me.
    Tim
    LRRS #44
  20. #420
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Eject System
    Lou has documented and commented first hand failure of his in his race report linked in this thread. It's no "some guy said". They attempted to use it after his crash. It didn't work.
    Apr 2011
    NH
    Re: Eject System
    ok good.
    1 confirmed attempt successful, one confirmed fail, real numbers thank you.
    Now the successful one, I'm not sure how you would quantify(is that the right word?) that if it saved him injury. But, if we got up to a few fails and still only one successful I would think the track, and I'm told it comes from above just NHMS, would look at it again. Keep your paperwork.
    Tim
    LRRS #44
  22. #422
    Eject System
    These bags only last two years right? So we're all replacing them before April 2015?
  23. #423
    Apr 2011
    NH
    Re: Eject System
    yup.
    plus my helmet is up in may or june and I don't think you can remove and reinstall them so I'm buying 2.
    Tim
    LRRS #44
  24. #424
    Posting Freak Gecko's Avatar
    Jul 2008
    Re: Eject System
    Quote Originally Posted by timmyho414 View Post
    Of those times I have been aware of a helmet expiring in the middle of a season, tech usually lets the helmet finish the season out. ymmv
    John
    CCS/LRRS Expert #69
    LRRS Rookie of the Year 2004
  25. #425
    Lifer union's Avatar
    Blackstone, MA
    Re: Eject System
    yup.
    I believe you can remove and reinstall them. If I remember correctly it tell you how in the instructions.
    James
  1. Replies: 7
    Last Post: 08-05-14, 04:04 PM
  2. Replies: 61
    Last Post: 10-29-13, 02:27 PM
  3. Replies: 1
    Last Post: 03-17-13, 02:49 PM
  4. transponder and helmet eject thing
    By burnham in forum Pit Area
    Last Post: 09-02-12, 11:32 AM
  5. helmet eject system
    By vintage ex race in forum Pit Area
    Last Post: 08-04-12, 05:29 PM
