Results 1 to 24 of 24
Engine Ice
    Be Squid, Be Proud bostongixxer's Avatar
    Dec 2005
    Cohasset
    Engine Ice
    I'm currently running water wetter in my gsxr for the track, but have heard that Engine Ice is track legal and can stay in the bike all year because it freezes at a much lower temp than water. I've also heard that Engine Ice is bad for the engine...I think someone at Penguin told me that last year, but never explained why. Any advice/thoughts on this?
    2020 KTM SMC R
    2006 GSXR-600 Race (LRRS #199)
    NO LIMIT
    Lifer GMAN226's Avatar
    Coventry RI
    Engine Ice
    I don't believe it is legal. Even if it is I have heard it is very slippery. You should drain and flush your bike over the winter anyway.. Stay with the Water Wetter just my .02
    G-man
    Gerard
    Lifer Wishbone's Avatar
    Jul 2006
    Engine Ice
    I put water wetter in over the winter for my street only bike. had it back out side in the late winter/early spring si it dipped into the teens a few nights with no noticeable problems if that helps
    Dec 2005
    Cohasset
    Engine Ice
    Quote Originally Posted by GMAN226 View Post
    G-man
    Well, if it's slippery I won't use it. I've considered running Engine Ice in my MV, as that bike runs really hot, but avoided it because of what I was told.
    2020 KTM SMC R
    NO LIMIT
    Lifer s a x m a n's Avatar
    Mar 2003
    Lee, MA
    Engine Ice
    engine ice is illegal at LRRS events
    Posting Freak Puppet's Avatar
    Oct 2004
    Seattle Area
    Engine Ice
    It's not legal for racing applications.
    I've been using it in my streetbikes for years with no noticeable negative side effects.
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Bench Racing World Champ Supah Dave's Avatar
    Feb 2007
    Boston, MA
    Engine Ice
    Engine Ice is legal in most racing organizations, but it IS NOT legal in LRRS. I flushed my cooling system last November and put Engine Ice in before heading down to Homestead for the CCS races in December (Engine Ice is legal in CCS). When I showed up at Loudon in April, I was told at tech to take it out because it is not allowed. I know some people that do use it and haven't been caught, but if a tech inspector actually checks your reservoir and sees it there's a chance you'll be told to remove it. It is slippery and I can tell you first hand that it doesn't work any better than Water Wetter does...
    CCS/ASRA Pro
    2010 Yamaha R6
    Engine Ice
    i run "cool-aid"
    Winchester, MA
    Engine Ice
    Quote Originally Posted by Supah Dave View Post
    Well that depends on your definition of "works better". It doesn't work any better at cooling (water is superior to all antifreezes in this respect), but it does work better at not freezing.
    Engine Ice is *still* just propylene glycol with fancy marketing. You can get this stuff at any auto parts store with a Prestone, et. al label for much less money/hassle than Engine Ice.
    Engine Ice
    Prestone uses ethylene glycol. BAD
    Engine Ice uses propylene glycol. Still slippery, but better for the environment. They say it's not toxic and it looks like gatorade!!!! Actually, propylene glycol is use in some medicines too!
    Winchester, MA
    Engine Ice
    Prestone makes a propylene glycol mix too. Pretty much all the manufacturers do, as there's lots of applications that require it like marine usage (can't kill all the fishes).
    Engine Ice just takes advantage of peoples' ignorance about it's ingredients, thinking that it offers some sort of fancy ass formulation that is "specially designed for racing" or some shit.
    Engine Ice
    I dump A 40 oz of St. Ides of King Cobra in there Works great and is not Slippery (Must be Malt Liquor as Beer does work as quick or effective)
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Feb 2004
    Bellingham, MA
    Engine Ice
    Engine ice is absolutely the best coolant I've used to date. Much better than water, or water with additives. How ever when it evaporates it turns to jelly and stays slippery for hours. That, and that alone is why we don't allow it at LRRS. I've used Red Line Water Wetter and Maxima's Cool-Aide and found them to be about the same. The additives basically are a lubricant for the water pump.
    Winchester, MA
    Engine Ice
    The only explanation I can give for that is that your bike must warp the fabric of the universe such that physical properties in its vicinity are not as we have traditionally observed them.
    I've heard that happens when you get down below the 15s.
    Feb 2004
    Bellingham, MA
    Engine Ice
    My KTM 125 would look like a fog machine when stuck going slow, or when the radiator was clogged with mud. It would boil away water every ride. I switched to Engine ice and have not ever had it over heat, loose power or use cooant since. In fact, I have the same coolant on it from 3 years ago. I just did a new piston & ring and reused the coolant it looked so good. Water is not the best conductor of heat. Ethylene Glycol is better, so is Propylene Glycol.
    Winchester, MA
    Engine Ice
    That's because adding the glycol raises the boiling point of the coolant. Once the coolant boils it becomes a really shitty coolant, so by raising the boiling temperature of the coolant you're creating a larger temeperature window that your bike can run in before the coolant boils and causes catastrophic overheating.
    However, pure water is still a better conductor of heat. Up to the point at which the water boils, it will remove more heat from the engine than any mixture of propylene or ethylene glycol.
    Engine Ice
    I run rusty water.
    Discuss.
    Engine Ice
    You can clean that with an aluminum magnet!
    Engine Ice
    Quote Originally Posted by mmracer37 View Post
    Then how will I know it's my coolant when it comes splashing out? I don't want confusion of to what is my coolant vs someone else's next time I wad her up.
    Sep 2006
    Around the corner
    Engine Ice
    i use murphey's oil soap ... lubes as it cleans
    The rule is:
    Dec 2005
    Cohasset
    Engine Ice
    Lots of great information...maybe I'll just pour a 2 liter bottle of Coke in.
    2020 KTM SMC R
    NO LIMIT
    Engine Ice
    That is absurd.
    Jul 2006
    Engine Ice
    what does prestone call it?
    Winchester, MA
    Engine Ice
    prestone lowtox
  1. wtb; 08+ R6 engine
    By sdog30 in forum Wanted
    Last Post: 07-13-13, 10:04 AM
  2. WTB: Engine stand and engine hoist
    By xrocket21 in forum Wanted
    Last Post: 07-15-10, 01:50 PM
  3. 94 FZR ENGINE
    By tiller in forum General Bike Related
    Last Post: 06-02-02, 08:48 PM
