Page 1 of 3 123 LastLast
Results 1 to 25 of 53
best fuel for stock gsxr600 motor?
    go faster cdovego's Avatar
    Weymouth
    Lightbulb best fuel for stock gsxr600 motor?
    Sponsor says run c12 or a 50/50 blend of c12/pump gas.
    Ecu is stock, motor stock, intake stock, exhaust is a slip on, no power commander.
    My gut says pump gas based on my highly calibrated butt dyno through the years.
    What do you think?
    Central Mass Powersports #123
    May 2010
    Somersworth, NH
    Re: best fuel for stock gsxr600 motor?
    no power comander... stock motor etc pfft just run the 93 at the track pumps
    Quote Originally Posted by Dove View Post
    Sponsor says
    There you have your scientific reasoning.
    Remember, finance is a science.
    Weymouth
    That's the thing though, why?
    cant mix fuels, so 50/50 of C12 isnt legal at NHMS.
    C12 is designed for the old 2-stroke bikes. dont use it.
    stock motor, use the 93 pump at NHMS.
    thinned head gasket, with full exhaust and high flow air filter....run Sunoco GT 260
    Weymouth
    4 stroke motard uses c12 - are we going down the rabbit hole with this topic?
    To get any gain out of a higher octane fuel you need to do one or more of the following:
    - Raise compression to take advantage of increased knock resistance
    - Advance ignition timing to account for higher octane's typically slower burn rate
    - Increase VE via porting/cam timing/etc or boost (turbo/supercharging) to raise combustion pressures
    - Adjust fueling to match
    To get any gain out of an oxygenated fuel, you need to adjust fueling to match otherwise you'll be running way lean and loose power.
    You haven't done any of those, or anything to improve the bike's breathing overall significantly. Your bike will make the most power on the lowest octane pump gas it'll run on without knocking. If racing with LRRS that means pump 93 from the track. Anything else is pissing money and HP away.
    C12 is a shitty fuel, but is one of the only leaded options allowed at LRRS.
    your best bet is 93 pump, then GT 260 once you get some higher compression.
    Lifer Stromper's Avatar
    Eastern Ct
    Benzene
    Toxic but more power
    The calculus of hate
    Weymouth
    I'm in complete agreeance and I guess was looking for some support to make sure I wasn't missing something.
    Perfect explanation, thank you for taking the time to type it out.
    tell your sponsor to pick up a rider than knows more about the 06-07 GSX-R 600
    Weymouth
    ha, make it worth their time and they will.
    Agreeance? You've been hanging out with Smutty too long.
    you mean my charming personality and handsome looks arent enough?
    ...wait, they sponsor smutty and he's ugly.
    I concord.
    You called????????????????????
    Weymouth
    School me, I was originally an english major in college. Is agreement the word I was looking for? I'm pretty ocd about words.
    We might need to get you an org. chart.
    I concord.
    This thread sucks.
    This thread sucks.
    Doc hasn't been anywhere near it.
    Nov 2007
    Kurlon is spot on. If the bike isn't tuned at all, it's likely set up from the factory to run optimally on 91 (not 93) in most cases. So if there are any race-legal 91 octane options, that's what you should run. If not then do the 93 at the track I guess.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    It's probably also tuned out of the gate for gas that if corn-free. Unfortunately, NHMS's 93 pump has ethanol in it.
    Weymouth
    Great, more maintenance.
    CSmutty - go back to work, the adults are talking.
    NHMS has 4% ethanol, where most pumps down 106 will have up to 10%.
    Diesel would be best for a gixxer...
  1. For Sale - Parts & Tools | WTS: 2012 Yamaha R1 stock clear wind screen, stock mufflers
    By Synyster in forum For Sale
    Last Post: 03-23-14, 09:13 PM
  2. Ninja 250 motor transplant... what motor to use?
    By DynoTune in forum General Bike Related
    Last Post: 01-06-14, 08:04 AM
  3. Wanted - Parts & Tools | 04 gsxr600/750 stock rear set.
    By FAST GSXR750 in forum Wanted
    Last Post: 12-16-13, 05:15 PM
  4. 04 busa stock full system 08 stock cans
    By Dannyf in forum For Sale
    Last Post: 08-21-11, 08:23 PM
  5. 08 R6 vs. 08 GSXR600
    By RyanNicholson in forum Pit Area
    Last Post: 11-05-07, 02:44 PM
