Results 1 to 25 of 40
Might be a little late this season.
    Lifer union's Avatar
    Blackstone, MA
    This year the R6 was due for a complete rebuild. So I tore it down.
    Not a big deal I had plenty of time.
    We did the same thing to the engine. Only have a photo because my camera decided to not work.
    We got it 100% complete last week and took it off to Robs Dyno to get the motor broken in and mapped. He has built himself a fucking awesome dyno room and a shop that is soon to be complete.
    YouTube - R6 Dyno.wmv
    115 at the wheel and 160 at the crank according to the dyno. It was running mint all day.
    However at the end of the day it decided to drop a cylinder. We shut it down and brought it home to find this.
    Cylinder 1 and 2 were functioning normally. 3 and 4 were tearing the case apart. The rings failed and scraped the lining off cylinder 3 and was working on 4.
    As we stand now the case is off getting replated with a 10-12 day turn around time. Hopefully we will get it back in time and together once again.
    James
    Wirelessly posted (Mozilla/5.0 (webOS/1.4.5; U; en-US) AppleWebKit/532.2 (KHTML, like Gecko) Version/1.0 Safari/532.2 Pre/1.0)
    dude,that sucks. Did you replace the rings in your tear down?
    Blackstone, MA
    Re: Might be a little late this season.
    Yes. Ring pistons. Pretty much brand new engine internals. I think maybe 3 transmission gears were reused.
    James
    ....... Nazo's Avatar
    Jul 2004
    tough break bro. Its always something!
    Hope you get it all back together in time
    Chris
    LRRS Expert #160
    aaah, that blows. I rebuilt my mini once only to blow it up on startup
    Wow that sucks! Hope you can get everything back together for the first weekend!
    Posting Freak Gecko's Avatar
    Jul 2008
    Damn, sorry to hear this James. Hope it comes together in time for the start of the season.
    John
    CCS/LRRS Expert #69
    LRRS Rookie of the Year 2004
    Lifer Danz19899's Avatar
    Grafton, Ma
    damn that stinks. I would just be very curious as to why they failed. I've only rebuilt 1 car engine so I'm not expert but. Were they getting oil properly? and are motorcycle rings directional? I know the engine I rebuilt the rings had a certain direction that had to be up on the compression side.
    don't doubt your knowledge just never seen an engine fail for no reason
    www.bostonmoto.com
    Ride to live, live to ride
    Blackstone, MA
    Quote Originally Posted by Danz19899 View Post
    We arent sure why yet. Best guess was due to detonation. It was getting plenty of oil and the rings were installed in the correct directions. On the ones that failed you can see that they did rotate for whatever reason.
    James
    Quote Originally Posted by union
    Rings do rotate, but I think dan meant correct way up. There is a stamped letter on oem rings indicating the beveled edge and this goes up.
    Blackstone, MA
    That was also correct. Go have a look next time youre there. I also want another can of gas
    James
    Grafton, Ma
    thats fricken weird. I'm out of ideas lol.
    In my limited experience i've actually never seen rings fail in such a catastrophic manor. I would look closer at the rings and cylinder walls themselves. Maybe poorly coated or just a junk set of rings?
    How loud was it? Cause detonation enough to cause that much damage would have been audible.
    Also If you don't mind me asking did you make as changes to the compression ratio when you rebuilt it?
    Dont mind me just thinking out loud
    www.bostonmoto.com
    Blackstone, MA
    In simple terms the cylinder walls in 3 and 4 are fucked. The case is currently out being replated. Thats the hold up.
    We did increase compression. We decked the head by .06 of an inch. We also went with a thinner head gasket. Everything measured within yamaha spec for a race motor. We are also using c12 for fuel. Most teams use a .45 mm gasket and we used a .40. The only thing I can think of was the deck could have been a little too low with the .40 even though the squish measured out above the minimum spec. Next rebuild will have the .50 gasket because the .45 has been on back order for 2 months now.
    James
    Lifer legalspeed's Avatar
    Somersworth, NH
    Do you have pics of all the piston tops? Are 3 & 4 the inside pair?
    LRRS\CCS\WERA #486
    Blackstone, MA
    Quote Originally Posted by legalspeed View Post
    They are all similar on the top.
    3 and 4 are the two on the riders right side.
    James
    Dec 2003
    Ma
    Did the bike really need the work in the first place?
    Blackstone, MA
    It did. We had 68% leak down in one cylinder and 50% in another. It was tired.
    James
    Somersworth, NH
    Isn't that typical pre-det dings?
    Who milled the heads?
    LRRS\CCS\WERA #486
    Somersworth, NH
    ...and sorry to hear, that's gotta suck especially right before the start of the new season.
    LRRS\CCS\WERA #486
    Blackstone, MA
    Harrys Machine. I think they have done a few
    James
    Mar 2004
    woonsocket ri
    There's still time. You just need to get Peter to stay up late and work on it while you go home.
    Blackstone, MA
    Quote Originally Posted by dhuze View Post
    Who says that isnt happening. We are in a holding pattern while we wait for the cases to come back. Hopefully no later then next week. Once they are in its full on build time. We can complete the bike in a day.
    James
    Mo hates it when people are latte.
    Tough break James, my season will start latte too...silly valves.
    Damn James, that motor sounded sick last weekend. I have faith that you'll be ready for round 1.
    Dec 2003
    Ma
    Replace it with OEM parts.....Honda OEM parts.
  1. Really Tardy, Late Season Ride Report Video
    By Phat Twin in forum Dirty Bastards
    Last Post: 01-12-09, 06:08 AM
  2. Awesome Late Season Off Ride Last Sunday
    Last Post: 11-06-07, 03:01 PM
  3. Late season Fatality
    By rjh200 in forum General Bike Related
    Last Post: 11-29-06, 02:53 PM
