Results 1 to 12 of 12
Hard Front Medium Rear ????
    I believe it was this past Moto GP that they mentioned that they were running a hard front and a Medium rear. I thought this was a no no.
    I'm guessing the track is so hard on front tires in the breaking and turns they needed a little extra life OR they want a little front end slip.
    Discuss!!!!
    Lifer s a x m a n's Avatar
    Mar 2003
    Lee, MA
    Re: Hard Front Medium Rear ????
    I just ran a Medium Front and Supersoft Rear this last race weekend ... LOVED IT!
    The front felt more stable under trail braking that I was able to trail further than I have before. Then the supersoft rear, what can I say ... GRIP!
    Did your chatter go away?
    Hmmm?
    Tire compound?
    Tire construction?
    Less flex?
    Stability?
    Mar 2003
    Lee, MA
    it was more stable for sure under heavy braking
    The transitions where a little quicker too because of less flex ... thought I only noticed in 1a to 2 and the chicane obviously.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Jamie - I'm not blaming tire, but I had some front end push in 10 last weekend on S and SS... I am fearing going to a harder front will only add to this... Any comment?
    It was happening off the gas, just at the end of or after any trail braking, and 15 ft/1 sec before cracking the throttle to get the front end light over the whoop section.
    My suspension is loosely bounced in from mike right now (since I forgot to make reference of my changes at the last rain weekend of '08), so it could be coming from somewhere else... totally made me check speed and lose confidence in 10 though. Had a very odd save once, front pushed a LOT (I think I may have gone over the oily new patch) - thuoght I was going down, but somehow recovered.
    Pirelli fronts can seemingly slide forever without throwing you down.
    Kitt, Cracking the throttle really early helps a lot in 10. Like up by the concrete wall on the left of the track. Settles everything early for the bumps and helps get some turning done before the bumps as well. Could solve the push problem to boot. Do you brake there on a clean lap? I don't think that's necessary.
    Mar 2003
    Lee, MA
    In 10 there is the patch where the bump was before the apex. This had very little traction compared to the rest of the pavement. I felt my front slide there many times if I just touched the corner of it. I had to make sure I came in tighter around 9 to avoid the patch.
    Lake Champlain, VT
    I brake hard on the curb of 9 (think im doing ok there)... then throttle through 9, sometimes I check speed (prob lack of sack) as I flick into 10. Even when I don't check speed, I'm not cracking the throttle that high... I could - but my brain is telling me lightening up the front where the front is already sliding may be sketchy.
    Mar 2003
    Lee, MA
    you need to do the opposite of what you brain thinks is right with front end slide ... getting on the throttle sooner will most likely clear it up
    Lifer Pittenger5's Avatar
    Austin
    Quote Originally Posted by s a x m a n View Post
    You would think me being an idiot would help me in racing. Nope, apparently the only time my IQ breaks normal levels is when Im racing and say, nope you shouldnt do that.
    Zip Tie Alley #505
    As mentioned above. You got a plowing situation. Release the front push with slight positive throttle. The key to figuring this out has already been done. You are already aware of this. You just have to overcome the fear. It takes a lot of laps and talking to yourself and calling yourself "you stupid idiot. Ask me how I know.
    I was thinking you could crack the throttle BEFORE the front slides. There's usually a frasction of a second there from tip in until tyou plough the front. It's almost always from too much tension in your arms. I would plough the front more as I got tired.
  1. Wanted - Gear | Wanted: Medium Snell 2010+ medium - long oval helmet
    By -Dutch- in forum Wanted
    Last Post: 07-23-17, 01:37 PM
  2. For Sale - Parts & Tools | Front & rear stands
    By MellowYellow in forum For Sale
    Last Post: 02-12-14, 09:07 PM
  3. Replies: 11
    Last Post: 08-08-13, 12:31 PM
  4. Front rear stands
    By slammp in forum For Sale
    Last Post: 05-24-11, 06:17 AM
  5. Front and Rear Stands
    By Mystic in forum For Sale
    Last Post: 11-24-09, 08:18 PM
