At VIR this weekend I wore my Garmin Forerunner 305. Its a heart rate monitor with a GPS. I discovered my heart rate is generally between 185-194 while racing. My max heart rate for my age is 195. So I know im about topping out. What can I do to lower this so I dont have a heart attack on the track?
http://connect.garmin.com/activity/13717063
This is the log from the weekend. I forgot to shut it off after each race so there is me riding around here and there.
breathe and relax yourself?
Holy crap?! Isn't that hummingbird territory?
Now I'm curious, can I borrow that some time? : )
wow that's high do some cardio man lol
make sure your breathing correctly sounds dumb but i had a buddy who always got winded on the track couldn't figure out why. one day we inverted a helmet cam and found that he would forget to breath in hard corners causing his heart rate to get high and oxygen get low
highest i've gotten is 180 bpm running with paintball gear on
I'm not a huge fan of running, but you need to do something to elelvate your heart rate for at least a half hour everyday. And fix your diet. The fat content in your diet is contributing to poor cardiac health.
Get out while you can
Find your own path
I manufacture endovascular stents for a living. Call me and we'll dilate some vessels to 16mm... should clear things up quite a bit.![]()
Fitz
Bicycle.
Run and bike. Biking will do the most for your heartrate. Just for a reference, Lance Armstrong and other top cyclists in the world carry a resting heartrate of below 40. Dean Karzanes (however you spell his name) is famous for running 50 marathons in 50 days. His is slightly lower. Although you don't need to get to that extreme, running will increase bloodflow. A marathoner has 3x the bloodflow of a sedentary person. This means more circulation, which is a good thing for your body. There's science behind it, but its not really important. Running and biking are good for you. Also, you'll never actually hit your max heart rate, you'll only get within 5% of it.
also, more heartrate goodness. Right now I rock a resting heartrate in the mid 70's bpm (20 years old), and when I'm in marathon shape, that drops to about 55 bpm.
Edit: Hummingbirds are like 400bpm.
my cousin and i recently started running, but i definitely need running shoes. i was getting massive shin splints(correct term?) with the shoes i have now. i just need to get down to this place with him. they have a tread mill you run on and it analyzes your feet as you run. so they can recommend specific shoes towards you. the reason i need him is so i can get the police officer discount :booyah:
As you get older, you lose max heartrate. I think you start at 210 or so and then its 1 or 2 bpm per year, depending on your fitness level. 1 if you're in shape, 2 if not.
Also, for your feet, you don't need to get those specially analyzed. Check runners world.com for a foot analyzer thing. They have you take a wet foot and step on a brown grocery bag, and depending on the shape that results, they recommend a certain type of shoe.
Also... running shoes.... don't buy into hype. I've run a lot of miles in several different shoes. My best advice is stay away from anything marketed to the public. Aisics (sp?) have always been good to me. Everything I've heard says Underarmour running shoes suck massive amounts of cock.
Lastly, and this is just personal preference, a pair of running shoes only lasts me about 200-250 miles, so I usually buy in the $70-90 range. There are some diesel shoes on the market for $140, but if I only get another 100 miles out of them, I can't justify the cost. Long story short, buy what feels right for you.
When I did cross country, I bought the cheapest no name wallyworld specials, velcro even. I think I paid $19 a pair? Comfort was fine, and if I trashed them with mud/etc, or lost em, whatever.
Edit: Resting rate - 60bpm, peak rate during wisdom teeth removal - 90bpm, averaged 70bpm
I usually only get bad shin splints when either:
a) I haven't run in a really long time and I push myself
b) I run outside for the first time in awhile (instead of on the treadmill)
Like Doc said, make sure you stretch well before each run. All major areas of the legs (calf/achilles, quad, groin, hamstring). I've noticed this makes a HUGE difference. Also do as long of a warm-up walk as you can (I've seen up to 5 minutes recommended, depending on the intensity of the run).
I buy New Balance running shoes, usually at Marshall's for pretty cheap $$. Most important part is fit (support plays a large role in this, it needs to fit more than just length/width).
