Results 1 to 25 of 27
So what is happening here?
    Just Registered Doc's Avatar
    Jericho, VT
    I was in the LWSB race and I kinda noticed the front of the Ducati kinda slid all the way threw 9. It didn't feel planted and I didn't feel like I could power through the way I wanted. I felt it a little in 11 and 1 as well. Any long corner really.
    Front Tire pressure was 28 cold, would get to 30-31 hot.
    Any ideas? Got a fix? I hadn't felt this before, of course I was going a good 4 seconds slower...
    Littering and........
    Jul 2004
    Vermont
    "Twist it, you pussy."
    -Peter Kates
    1/8 of a liter is plenty SilverDragon's Avatar
    Pittsfield, MA
    I have been told that if your front is not moving yet, you're not going fast enough - Especially through 9.
    Neal Mulcahy
    LRRS/CCS #427 ECK-Racing 2009
    Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | Motorcycles of Manchester | BostonMoto-Pirelli
    Foxboro, MA
    Quote Originally Posted by SilverDragon View Post
    for real? thats interesting - i guess i have yet to go fast enough at all
    any reasoning behind that thought?
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Jericho, VT
    So your saying I am starting to get fast? I bet I can fix it with some suspension tweaking.
    Mmmm, I'm not sure that's a productive idea. Holding the bars too tight is still 99% reason for all slides, front and rear. The faster I got through nine, the better the front hooked up on my 125.
    Now in the end, it's possible to relax enough to carry so much speed that the bike will drift both ends before fully hooking up, but that's out of reach for 99% of the riders 99% of the time.
    Better to focus on getting it hooked up. just good basic riding technique and having a good "map" of the corner will get you there.
    Have PK do his push/pull routine & if the problem persists, do what I do.... ignore it and ride through it
    Jericho, VT
    Ok so I need to relax more and probably work on my body position through there then.
    It was predictable and seemed to "push" no matter what I did. I will work on it before I start fiddling with suspension.
    Jericho, VT
    i wanted him to do that on the Hawk but I guess it was too far out of his league to deal with the mess.
    The Duc feels MUCH better suspension wise, The Hawk seems kinda soft.
    Lifer Pittenger5's Avatar
    Austin
    Suspension? Who needs suspension! I just bounce my way right through 9, its half the fun
    Zip Tie Alley #505
    Same here! Dragging hard parts means less weight for the suspension to have to deal with.
    Full Tilt - Full Time Trackday Guru's Avatar
    Dec 2006
    Concord, NH
    A vague feeling front end will have different causes at a 1:30 laps time than it will at a 1:17 lap time.
    So help us help you; What kind of lap times are you running?
    Mike
    Am #124
    Jericho, VT
    1:23- 1:24's
    http://www.lrrsracing.com/results/20...n/Sun13Lap.pdf
    Michael Lemire #116 2nd place!
    Just Registered 13's Avatar
    Dec 2003
    Auburn, NH
    I've found that when I'm running 1:25s I get SEVERE chatter through 9. At 1:21s I have no chatter at all.
    Just go faster.
    One of the former LRRS #13's
    http://www.facebook.com/ChrisWatt762
    JT42
    1:23- 1:24's
    CHEEEEAAAATERRRRRR BIKE!!!! CHEEEEAAAATERRRRRR BIKE!!!!
    Lifer GMAN226's Avatar
    Coventry RI
    what tires are you using on that bike? Also what kind of chatter is it?? Is it sliding or hopping??
    G-man
    Gerard
    Never Enough HP kawi997's Avatar
    May 2007
    Uxbridge, Ma/ Center Barnstead, Nh
    well my ex likes to somtimes slide the front out, then the back, then the front, and then it comes back and the rear wheel lifts up then the amazing horsepower brings the front up. i've found that if you feed it carrots right after the apple, it calms it down. just my imput. hope it helps.
    Lrrs# 997 Ameture
    03 DUCATI 749S(Race)
    06 Chevy Cobalt SS
    Jericho, VT
    I have the PP race softs. It is not chatter it felt like sliding or pushing.
    Jericho, VT
    You Hush!
    Coventry RI
    Those tires are good but the front is a little vague until you get to full lean angle. Are you sure that is not what you are feeling... Plus those bikes need to be stood on their head to get any feeling out of the front end. That frame is the same as my bike so you probably need a TON more ride height...
    Just my .02
    G-man
    Gerard
    Jericho, VT
    I was told this before by Kyle Thompson of BCM. Thanks for confirming
    I changed the bars from clip ons to Helibars for a shorter reach, Iam sure this didn't help much.
    Looks like I can increase the ride height a bit as well. I am gonna have to stop by Garage 15 in October.
    And know I wouldn't call it "vague" but I guess I could... really felt like it was just barely starting to slide, like if I pushed it more it would slide out.
    Lifer smf's Avatar
    Nov 2006
    ...hobbs, now doc. why is T1a breeding these damn things all of a sudden??
    and btw, isn't 31 hot off the track a little high for that front tire? i know the rear likes to be motard-low on pressure.
    Scott
    Dec 2003
    Ma
    4 seconds slower? twist the throttle and get the weight off the front, you're scrubbing too much speed and overloading it, then making it worse getting nervous and tightening up your muscles and getting into a nervous body position.
    Jericho, VT
    No No No... 4 seconds FASTER....
    I wanted to go faster but felt if I twisted it that it was gonna slide out. I think I need to hang off more, with the Hawk I get my knee down all through 9, with the Duc it is taller so more difficult to do, plus the same body position might not work.
    Dec 2003
    Ma
  1. Whats happening ???
    By Big R 508 in forum Welcome and Intro
    Last Post: 11-08-07, 07:14 PM
