Results 1 to 25 of 27
Hey Degs why is it when I tell people.
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    To do the brake trick I lerned from YOU . THE ZIP TIE TRICK
    ZIP TIE YOUR BRAKE LEVER OVER NIGHT. I know your brakes are fine.
    DO THIS & TELL ME IT DON'T FEEL LIKE NEW BRAKES.
    MY GOD WHAT A IMPROVMENT.
    www.bostonmoto.com
    Forum Rules
    What's it supposed to do? Does it aid in bleeding?
    Just Registered Doc's Avatar
    Jericho, VT
    I think it allows any air bubbles to rise into your master cylinder.
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    works great too
    Gonna have to try that sometime.
    Lost in my own mind... 01YZF6's Avatar
    Mount Washington, NH / Stowe, VT
    been using this trick for years on my other bikes, make sure you have the reservoir cap OFF and a way to keep crap from drifting into the res. a clean cloth to loosely cover it works well. let it sit overnight like this ( 4-6 hours minimum)
    look out for that first front brake grab, it can catch ya off guard.
    if after 2-3 days of riding with it you feel the brake lever return to a spongy feel, it is time to repair/replace your calipers or brake lines.
    it is time to ride B!TCHEZ !
    1/8 of a liter is plenty SilverDragon's Avatar
    Pittsfield, MA
    If you leave your cap off, the fluid will absorb moisture and that will being the boiling point down. Don't recommend the cap off part.
    Neal Mulcahy
    LRRS/CCS #427 ECK-Racing 2009
    Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | Motorcycles of Manchester | BostonMoto-Pirelli
    Sooooooooo
    Zip tie brake lever with reservoir cap on, overnight.
    Do I have it right?
    Got Boost? katana0215's Avatar
    Feb 2004
    Warwick RI
    I dont think that will work, where will the air escape from?
    Foxboro, MA
    Quote Originally Posted by katana0215 View Post
    loose clean cloth over it
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Feb 2004
    Warwick RI
    Quote Originally Posted by Smooth R6 View Post
    I meant if you kept the cover on like Silver stated
    Feb 2004
    Warwick RI
    Quote Originally Posted by Frankenstein View Post
    Into the resevoir on the master cylinder. The point is to get the air out of the lines. There's always air in the resevoir.
    but if the res is sealed and presumably filled with air, would you be able to add more air to it?
    Foxboro, MA
    air moves up - fluid moves down
    2006 Yamaha R6
    There are pinholes in the cap. If not, your brakes would lock when heated.
    Lifer Pittenger5's Avatar
    Austin
    And if youre coming out of the bowl and your brakes heat and lock you end up with a broken thumb. Trust me.
    Zip Tie Alley #505
    Jericho, VT
    Fluid is compressible. It is just harder.
    Feb 2004
    Warwick RI
    d'uh, thanks. so I guess you could leave the cap on
    I tried this overnight and damn, what a difference. I guess I had some air bubbles in my front lines.
    My question is this:
    Why?
    What is causing this to happen?
    Does making any trapped air bubbles smaller through compression allow them to rise upwards in the system when their normal size does not allow it?
    Is it the constant pressure on the calipers (floating) that make them slide on their pins farther to have a resting place closer to ideal?
    I just want to know why! WOOOOOOO!
    May 2002
    Meriden CT
    I tell ya carefull first time ya grab um. good your slow but ya listen.
    www.bostonmoto.com
    Forum Rules
    Or, is this causing an airation of the brake fluid through pressure. Similar to how some beer is carbonated. If you let it sit long enough under pressure, the CO2 gets absorbed into the beer and the air into the brake fluid possibly. That would give you less trapped air pockets but would keep the amount of air in the system the same.
    Just thinking out loud.....
    Hm.... That sounds like a possibility...
    My understanding of it was, pressurize the fluid, increase it's density, reduce the solubility of the air. air comes out of the solution & rises to the top.
    May 2002
    Meriden CT
    who cares it fucking works
    www.bostonmoto.com
    Forum Rules
    well why do'nt you fuckin tell us then.
    It's maaaaaagic!!
  1. Degs is the man!
    By akira700 in forum Bike Maintenance
    Last Post: 04-19-09, 09:09 PM
