Page 4 of 4 FirstFirst 1234
Results 76 to 85 of 85
hyperpro steering damper
  1. #76
    Re: hyperpro steering damper
    ahhhh, another opportunity for CEO to post hi-res pictures of himself or his bike
  2. #77
    Nov 2007
    Quote Originally Posted by DBKromz View Post
    Um yes, in response to to people who asked for them
    You're really shoehorning all of your jokes lately Jim... it feels forced... you've lost your edge
    Zip-Tie Alley Racing
    LRRS/CCS #103
  3. #78
    Lifer obsolete's Avatar
    Norf Sho
    What's the switch for?
    -Alex
  4. #79
    Nov 2007
    It replaces the ignition, i.e. it is the key barrel's on and off positions.
    as a result there is no longer an ability to lock the steering
    LRRS/CCS #103
  5. #80
    Lifer Pittenger5's Avatar
    Austin
    Nos.
    Zip Tie Alley #505
  6. #81
    Norf Sho
    Quote Originally Posted by ceo and a bunch of numbers View Post
    Oh yea, I didn't read the post asking for the pictures. Just saw yours.
    Nitrous would be cooler.
    -Alex
  7. #82
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    they were very helpful to those of us who work on our bikes, not buy them set-up... Thanks chris.
    Is this pretty similar for all bikes? I'd love to replace the keyed ignition on the SV.
  9. #84
    Norf Sho
    Quote Originally Posted by 07BladeRider View Post
    You should be able to on any bike. It's just a matter of getting all the right wires. The tumbler is just a switch essentially, unless there is an imobilizer.
    -Alex
  10. #85
    Nov 2007
    Sure.
    The trickiest part is getting the old ignition off from the triple. They use those safety bolts that at a given torque the part of the head with the hex shears off, leaving just a cap with nothing to grab. You basically have to dremel that entire head off and then the igntion just slides off the bolts/studs. Then you can either cut or unscrew with vice grips the studs to get them off the triple.
    Also you'll notice the bracket on the right side for the damper replaces the two bolts for the fairing stay / ram air setup with longer ones so the bracket fits there. On the other side is a simple 50mm fork clamp from Traxxion.
    Yes usually you just need to figure out what wires to jump. Most common is two jumped like in mine and then two to a switch.
    Only thing is, It's info that isn't always that readily available online because it basically tells someone how to steal your bike. Personally I don't think douchey bike thieves scour the interwebz looking for theft instructions so I'm not worried about it, some folks are very adverse to postings like it/this though.
    LRRS/CCS #103
  1. Any Experience with Hyperpro Steering Damper?
    By Trajiks9 in forum General Bike Related
    Last Post: 03-31-16, 04:47 PM
  2. Steering Damper
    By Larry in forum Wanted
    Last Post: 08-23-12, 09:12 PM
  3. too good to be true? HyperPro Steering Damper, $22...
    By island boyeee in forum General Bike Related
    Last Post: 09-12-11, 02:11 PM
  4. WTB Steering Damper 03 r6
    By Jenni in forum Wanted
    Last Post: 01-22-10, 09:25 AM
  5. HYPERPRO ACTIVE CONTROL DAMPERS or SCOTTS ROTARY STEERING DAMPER
    By greco954 in forum General Bike Related
    Last Post: 06-28-04, 04:00 PM
