Results 1 to 13 of 13
SV belly pan
    SV belly pan
    Sold my bodywork and looking to see if someone has any ideas on what will work for a belly pan for a gen 1 SV 650. I'm going to race naked this year and my options looks limited. I can't find a DR404 belly pan like darkducs and I'm at a loss besides bending/welding up some aluminum to fashion a pan.
    Anyone else running anything differently?
    Lifer JettaJayGLS's Avatar
    Tahoe City
    Re: SV belly pan
    Quote Originally Posted by jcbell1007 View Post
    Most of us motard folks run the ebay one. I had it attached with hose clamps through the white tabs but those sheared off all the mounts in a crash or two. Now I just safety wire it on through the rivet holes and I passed tech every time. It is also probably more sturdy than the hose clamps and quick to remove and put back on.
    http://www.ebay.com/itm/Supermoto-Be...8f710c&vxp=mtr
    Only issue I forsee on the SV is the fluid retention...my crf carries less than one quart of oil and less than one quart of tranny fluid.
    Hiram, ME
    Re: SV belly pan
    For about half of last season, I ran a cut down belly pan to replace the Armour Bodies lower that finally gave up the ghost after two HARD crashes and being run over once. I sort of hacked it, since I had another set of bodywork that was going to go on(and still is, dammit!), but I bet something like this could work nicer with some aluminum brackets. Basically any race lower could be used.
    SV belly pan-259739_482065558472787_1197189148_o-jpg
    Re: SV belly pan
    hmmm. interesting. I might go this route. My main concern is tech for the fluid retention as the SV carries 3 Qts or so.
    Just Registered Doc's Avatar
    Jericho, VT
    Re: SV belly pan
    Nice Carbon makes a bigger one.
    You could also look for a GSXR race lower and make it work.
    Re: SV belly pan
    Carbon? I tried ebay but no luck. do you have a link?
    Re: SV belly pan
    found this one
    http://www.yoyodyneti.com/ProductInf...ctid=SS018042G
    I think i'm gonna order it in case anyone else is looking darkduc7
    Jericho, VT
    Re: SV belly pan
    They used to be on ebay and I may have them saved, let me check when I get home.
    Links are in this old thread: http://www.nestreetriders.com/forum/...ower-for-SV650
    ... might not be good, can't get ebay links at work
    Jericho, VT
    Lifer Trouble's Avatar
    Monkton, VT
    Re: SV belly pan
    Ouch. That belly pan is about $140 plus shipping from the UK.
    LRRS EX #7
    Low Down Racing
    Re: SV belly pan
    just ordered the yoyodyne one. $78, in stock.
    thrilled brady's Avatar
    Nov 2007
    Raymond, NH
    Re: SV belly pan
    I just ordered a spare, best and cheapest pan I've found. I'll post up mounting pics here too if I remember.
    Nov 2007
    Raymond, NH
    Re: SV belly pan
    SV belly pan-sebimotobellypan001med-jpg
    SV belly pan-sebimotobellypan-002med-jpg
  1. Lost: Belly Pan
    By ThunderCycle in forum Pit Area
    Last Post: 10-17-11, 07:20 PM
  2. Fiberglass Belly Pan ?
    By Pearldog in forum General Bike Related
    Last Post: 04-15-04, 07:38 AM
