1
Look at what happens on track, those 'massive 1100cc monstahs' are not blowing away everything else. What's winning LWSS, LWSB, and even LWGP? SVs and ERs. The 565s didn't strike me as dominating either this weekend.
What's the cost to make one of these 545 bikes?
#277
Destroke the crank - couple thou plus
Custom rods - Thou plus
Powercommander / Bazzaz / Kit ECU / etc - Pick your poison
Now, if you want to actually make it fast, plan on custom pistons, pretty heavy head epoxy/porting, custom cams and timing, aka a full on superbike build but there are not as many details nailed down due to the lack of iterations for development.
And just for fun: https://docs.google.com/spreadsheets...YE8/edit#gid=0
All I was proving is jesse sandoz is a damn good rider. It's not all bike.
Racing organizations have been struggling with parity for, well, pretty much forever. The hard part is, how do you quantify it? Power/weight ratios are the common choice but even that leaves a lot to be desired. A 125cc GP bike has a great power to weight ratio unless you're on a circuit with a long straight. Or uphill sections. Or...
If you try just going with native cylinder limits then you have the problem that water-cooled bikes make more specific power than air-cooled/oil-cooled ones.
This is why I'm glad that I studied Economics. You get to point out problems and then say "Gee, that looks tricky" and then go do something else.
Where's my wallet ARGH FUCK YOUUUUUU
I'm sporting a full chub right now.
well Doucette is a great rider too. and if you put him in one of those he will probably be unbeatable. and lets not forget that CCS is not located ONLY in LRRS where the talent can make up for the power..
Put Doucette against the Bimotas and Ducs in Daytona to see what happens. Hell maybe even Jersey. but thats too much bench and theory racing.
the reality is simple. It is an 1100 bike in the same class as a 650. Shit I race SuperTwins and Thunderbike but i am fully aware I race a class up.
Dont forget LRRS banned SVs from ULSB because it was unfair to other bikes. CCS did not. This is not much different.
Honestly. Get the bike that is most competitive in a class. Run that class. Don't look back.
Don't complain if you didn't buy the best bike for your class.
Hawks.
The rule structure for P89 is biased towards old Ducs and Hawks. You'll note the don't allow FZRs or other legal four cylinders the same displacement they do in P89 that they do in ULSB where they're facing the same twins. It's also setup to be compatible with the USCRA's Period 4 class so take a look at what they're running.
I'd race a Harley 1500 up against an ex500 anytime
I just think there's more to it than displacement.
I miss that crazy XR1200R...
I don't know, a few years back, Chris Rau walked all over everyone with an FZR400, bored out to the max of 560. No one could keep up with him, not even my 83hp SV Superbike. His FZR had to be making at least 85 or more. He would just pull me by at least 1-2 lengths on the front straight every time.
Problem with the old spacer plate 560 motors is they are grenades. First time you start it up you pull the pin, from there it's a guessing game as to how short the fuse is. That's why you just don't see them any more. There is a newer way to get to 560 that should be more reliable, I'd like to try one to compare to the route I went, but I only know of a couple out there.
