Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
Motard Pressures...same as big bike
    Re: Motard Pressures...same as big bike
    Jay, you are right also. There are lots of things flexing and moving around, trying to find the balance is the key.
    I've been thinking about the physics of it and wonder if it has anything to do with the lower pressure allowing the tire to flex and unflex in the left right direction, more pressure less flex and movement.
    I'm no expert, but I think what happens is mare that the soft tire has enough grip to quickly wind up the flexible forks until the tires pointing the wrong way and has no choice but to "jump" off the pavement to unwind the forks and get it pointing in the right direction again. Once this starts you get an oscilation like a tiny tankslapper and the wheel chatters away.
    Less grip through higher pressure and harder compounds doesn't wind up the forks as much and possibly slides a little instead of "jumping" to get straightened out.
    Lifer Pittenger5's Avatar
    Austin
    WEll Ill be damned.
    Zip Tie Alley #505
    Dec 2003
    Ma
    ah, I can see that too.
    Austin
    Is this chatter under braking, turning or acceleration? Or all 3?
    Zip Tie Alley #505
    Pretty much all.
    It would be really cool to get a high speed video camera in turn nine, then we could actually see how dramatic it is.
    Austin
    Quote Originally Posted by mmracer37 View Post
    Pretty much all.
    Call up Time Warp on the discovery channel haha
    Zip Tie Alley #505
    That's a great idea!
    Dec 2003
    Ma
    Mid corner 9 and 1 are the places I've noticed it the most. Harder on the gas helps too.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Yea cause getting on the gas, same as applying rear brake, takes pressure off the front.
    I get horrid chatter in T1A of all places. Just skip skip skips along.
    Boston --> San Diego
    KB KB's Avatar
    Manchester NH
    This chatter thing scares me. I'm glad I'm not fast.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Lifer lrrs313's Avatar
    Asheville, NC
    Pretty much all.
    Good idea. But I'm not sure I WANT to see what it looks like -- I know what it feels like, and that's bad enough.
    Dec 2003
    Ma
    Yup, 1A too depending on the line I take. Forgot about that one. I blame myself a little on it, not used to rights enough to make the quick full commit and come back. Gotta work on that.
  1. Street pressures for Dunlop DOT's?
    By Femmekat in forum General Bike Related
    Last Post: 11-14-10, 08:50 AM
  2. ex500 tire pressures
    By catch2otwo in forum Bike Maintenance
    Last Post: 03-04-09, 10:42 PM
  3. Replies: 15
    Last Post: 09-11-08, 09:57 PM
  4. Tire pressures, etc
    By TheIglu in forum Dirty Bastards
    Last Post: 10-27-06, 04:06 PM
  5. dirt bike -> motard???
    By Qfactor in forum General Bike Related
    Last Post: 04-12-06, 12:27 PM
