Results 1 to 18 of 18
ULSB Numbers
    ULSB Numbers
    Seeing as we've got a bunch of ULSB peeps in here, can I pester for some ballpark numbers from y'all? I'm looking for wet weight and HP on the various options. Hawks are 50 to 70hp, 280lbs to 320lbs? Duc 800s can be up to 80hp, 300lbs to 350lbs? Or am I way off?
    Lifer Pittenger5's Avatar
    Austin
    Re: ULSB Numbers
    240 lbs 51 hp
    Zip Tie Alley #505
    Re: ULSB Numbers
    240 lbs 51 hp
    Right, forgot about 'tards... btw, your bike isn't 240lbs when wet and ready. : )
    Austin
    Re: ULSB Numbers
    It was something like that, I weighed it on the nascar scales one weekend.
    Zip Tie Alley #505
    Lifer lrrs313's Avatar
    Asheville, NC
    Wirelessly posted (BB Tour: BlackBerry9630/4.7.1.61 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    60hp and 250lbs or so.
    -Brian
    15 S-Works Venge
    Lifer smf's Avatar
    Nov 2006
    Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 3_1_3 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7E18 Safari/528.16)
    hawk, 73 hp, 326 lbs
    btw getting a sub-310 lb hawk requires quite a bit of work.
    Scott
    Re: ULSB Numbers
    Damn, you're right, I was figuring a dry weight of 240lbs for most 'tards, looks like the RM-Z is closer to 220lbs before you add twice as much oil as necessary. : )
    Re: ULSB Numbers
    Quote Originally Posted by smf View Post
    I thought you were under that mark for some reason, it was your bike I was thinking of in the 280lb range. This is why I don't go by memory for this crap any more... I'm way off base all over the place.
    Austin
    Re: ULSB Numbers
    Quote Originally Posted by lrrs313 View Post
    60hp? Sheeyit. Can I borrow your bike?
    Zip Tie Alley #505
    Asheville, NC
    Re: ULSB Numbers
    Dyno'd on Rob's Dyno at 59.7hp with one full season on the piston. And that was before I put the cam in it. When I get the money to redo the head, I'm guessing 62-65hp, depending on how much I decide to do as far as port/polish, etc. If I get really crazy I'm pretty sure I can get 70 out of it relatively safely.
    And yeah, come on back next year and you're welcome to take it for a spin.
    -Brian
    15 S-Works Venge
    Austin
    Re: ULSB Numbers
    Im gonna hate you as much as I hated that dude on the Ape.
    Zip Tie Alley #505
    Re: ULSB Numbers
    From my reading, 70hp is doable without making a grenade out of 'em. BTW, I know where there is a 'special' part that you've been looking for up for sale. : )
    Asheville, NC
    Quote Originally Posted by Kurlon
    Really.......somebody buy my 450!
    -Brian
    15 S-Works Venge
    Asheville, NC
    Quote Originally Posted by Pittenger5
    And the next time I'm going to be a lot lighter too. 23 lbs and counting.
    -Brian
    15 S-Works Venge
    Just Registered Doc's Avatar
    Jericho, VT
    Re: ULSB Numbers
    I am hoping to be right around where SMF is (although I bet my bike will be a little heavier)
    The 800ss I had was 76hp IIRC, not sure of the weight but i felt pretty light. 350?
    Lifer smf's Avatar
    Nov 2006
    that would be JD hord's bike (Midwest hawk god). He also puts out very close to 90hp at the wheel. I dream of getting below 320lbs.
    Scott
    Re: ULSB Numbers
    So, net result, 280lbs, 50hp to 55hp really won't be up to par it sounds like. I'd need to find another 10hp, or drop 40lbs or more.
    Re: ULSB Numbers
    Henry - 71HP 340# Dual front disk up front. Scott has a Single.
    I ran a stock Hawk as a novice- 55 hp -340# in the 1:22.5. Mr. Watts was, I think, 1:22.0 as an AM.
  1. ULSB Video #428 May14
    By lrrs428 in forum Race Reports
    Last Post: 05-20-14, 06:27 AM
  2. ULSB ??????
    By nt650hawk in forum Pit Area
    Last Post: 05-18-11, 06:05 PM
  3. ULSB weapon?
    By Kurlon in forum Pit Area
    Last Post: 04-09-09, 08:42 PM
  4. 08 LRRS #7 ULSB Gino's RR for win#5
    Last Post: 09-06-08, 11:58 AM
  5. ULSB win #2 for 08
    Last Post: 06-04-08, 01:59 PM
