Seeing as we've got a bunch of ULSB peeps in here, can I pester for some ballpark numbers from y'all? I'm looking for wet weight and HP on the various options. Hawks are 50 to 70hp, 280lbs to 320lbs? Duc 800s can be up to 80hp, 300lbs to 350lbs? Or am I way off?
Wirelessly posted (BB Tour: BlackBerry9630/4.7.1.61 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
60hp and 250lbs or so.
-Brian
15 S-Works Venge
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 3_1_3 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7E18 Safari/528.16)
hawk, 73 hp, 326 lbs
btw getting a sub-310 lb hawk requires quite a bit of work.
Scott
Dyno'd on Rob's Dyno at 59.7hp with one full season on the piston. And that was before I put the cam in it. When I get the money to redo the head, I'm guessing 62-65hp, depending on how much I decide to do as far as port/polish, etc. If I get really crazy I'm pretty sure I can get 70 out of it relatively safely.
And yeah, come on back next year and you're welcome to take it for a spin.
-Brian
15 S-Works Venge
From my reading, 70hp is doable without making a grenade out of 'em. BTW, I know where there is a 'special' part that you've been looking for up for sale. : )
Really.......somebody buy my 450!Originally Posted by Kurlon
-Brian
15 S-Works Venge
And the next time I'm going to be a lot lighter too. 23 lbs and counting.Originally Posted by Pittenger5
-Brian
15 S-Works Venge
I am hoping to be right around where SMF is (although I bet my bike will be a little heavier)
The 800ss I had was 76hp IIRC, not sure of the weight but i felt pretty light. 350?
that would be JD hord's bike (Midwest hawk god). He also puts out very close to 90hp at the wheel. I dream of getting below 320lbs.
Scott
So, net result, 280lbs, 50hp to 55hp really won't be up to par it sounds like. I'd need to find another 10hp, or drop 40lbs or more.
Henry - 71HP 340# Dual front disk up front. Scott has a Single.
I ran a stock Hawk as a novice- 55 hp -340# in the 1:22.5. Mr. Watts was, I think, 1:22.0 as an AM.
