I took notes on my riding but it was really short bullet points
- tried turning in early in Turn X, seemed to work better, will work on more next practice.
- Bump in Turn X causing issues, finding going to the inside is better
- Gearing too short, went up +1, laptimes better
etc.
Funny to read my notes from 2005
Boston --> San Diego
thats pretty much exactly what I meanfrom my experience on the track, its good to find a balance between having specific points, thoughts, and strategies to think about....and "feeling/rhythm". Its pretty easy to over analyze.
You're right, there are a number of ways to do it, but swinging really wide to the right side of the track after T1a isn't something any of the fast guys I've been out there with do. Since there is a significant amount of turning to do after the apex, that even with a later apex you can't really do much about...it seems like you're just giving up a bit for very little gain. But, like many of said here already, lines do change depending on rider/bike/etc.
Its one of the very deceiving, strange, odd corners at NHMS that aren't all that common elsewhere. Like T1....the preturn doesn't initially seem like it would be the fastest way around it....but it is.
yea, basically...like i said i wouldn't really want to pull hard, but a little pressure on the bars to help stand the bike up can help you get on the gas harder, sooner.
C O N --- F I D --- E N C E :: F E A R
Better Laps/ Faster lap times :: C R A S H I N G
you'll get there man just practice what works for you ..... with a fast guy tip here or there
Last edited by The Crashing Tomato; 08-21-08 at 01:59 PM. Reason: non conducive to the thread
Originally Posted by hammadown .....The rule is:
NOTE: Didn't read all the posts, but...
I believe the fastest way through Turn 2 may not be the safest.
We try to get people to hold Turn 1A a little longer...thus getting more of your turning done down on the flat... before starting up the Oval. This way, if you tuck the front you'll probably not even reach the airfence.
Also, if you do highside, since you're pointing much more toward Turn 3, you'll likely not flip over into the fence.
And since you don't have any inside passes allowed in 2, you don't have to worry about that.
I think (been outta the racing scene for a while, so maybe not?) the new fast way is to almost straight shoot turn 1A and deal with Turn 2 up on the oval a lot more. I've tried it and it does seem faster... but I am also doing a lot more turning near the airfence.
There is a line I was shown where you late apex 2 and dive under the usual line of drifting out to the wall. IF you get a good drive you can beat someone to the chute in 3.
Interesting info about 2... guess your line really depends on the situation... track day vs. someone on your tail vs. trying to pass someone, etc...
That's sensible for someone who's already got a lot of their riding skills sorted out. I sometimes do short notes like that between sessions... it's after a day or two of sessions that I look at the entire track and everything I'm doing on it.
Or maybe this is all just to help me pass the time between track days?
On one hand I feel like I might be doing that a bit, especially at my level... but on the other hand I think it's important to know everything you're doing in order to make changes and be able to get consistent with inputs.
At least we're getting some good discussion about it
Appreciate your help Ryan and others too.
Hey this is like the SAT's
Yeah I'll get there... I just like to think things through and try to do them the best way possible because I'm basically insane.
With that in mind, it certainly makes sense to teach the late apex line at your TD's, T. Especially with the transitions onto the oval and such, which make things hairy if you have handlebar pressure...
Zip-Tie Alley Racing
LRRS/CCS #103
I think Tony did a better job explaining my point about T2 and why there are a few different lines through there.
Though I suppose thats probably one of the reasons TTD is what it is
A lot of my advice here pertains mostly to a race environment Chris, since I know you're planning to start...I think the major difference that defines that would be the efficiency of getting around the track the fastest way possible (ie, a straighter line into T2 means you carry more corner speed around 1A, which means you can get on the gas harder after T1, etc) vs at a trackday its more about refining the general riding skills that will let you accomplish that in a safe environment.
if that makes sense
basically.... I just like riding motorcycles and talking about going fast on them.
Sorry... "Turn 1A: Entry from about 2/3 across the track (from the right) and take it tight, you want to be looking at the cones on the FAR right of T2 as you enter... this will bring your line tight around the apex and stay wide right setting up entry to T2.
Turn 2: Staying to the right lets you apex Turn 2, and you'll be surprised at how fast you can take this corner if you make a larger arc. E. Wood uses all the track from 1A, tight apex on 2 and nearly hits the wall coming out he's on the gas so hard."
I didn't say LATE Apex... the "wide right" may be what was throwing you off.
What I mean is again, E.Wood and the super fast guys take 1A so friggin tight, their knee pucks are just hovering above the very top of the curbing... personally I really don't have the sac for that, but new to mid-fast guys are safely 2-3' off the curb, almost enough to get your knee on the ground inside the curb here... I've just noticed over the years how tight the fast guys stay to the inside curbing in 1A, it's incredible to watch.
Turn 2 there are absolutely different lines, some late apex, some do as Tony mentioned where you run up the transition and get your turning done closer to the airfence... I'm not sure I can tell you what the quickest line is, as it all depends on the situation. With a clear track, the quickest line is (almost) always the one with the shallowest arc... e.g.: if you're NOT late apexing T2, you shouldn't be driving up the track on the middle / left side of the straight... you aren't carrying enough speed if you're way over there with a normal apex. You want to drift all the way up to the wall / airfence coming out of T2 with a clear track, and use all the track... from the curbing inside 1A to the wall down the back straight... the fast guys don't leave much track unused there!!!
Sorry for any confusionI also am impressed with your initiative to keep a journal, and Penguin or the 2 Day "Pro" school will definitely help loads here.
Sounds like Eric's pro class speach.
Good job catalogging and posting, it should serve as a reference thread for those of us trying to get faster.
Yes Tony, apex to apex thru 1-1a-2 then slide, pin. It is a lot more risky, but after you do it a while it isn't so bad. Stand around 3 and watch as any of the sub 15 guys come out of 2 and see the drift!![]()
LRRS\CCS\WERA #486
Actually in 2005 I'd just started racing and was taking those notes during the 6 race weekends I did. Never did a trackday prior to racing (ack the horror!), so... I was still sorting everything out.
You know, I have ton a bunch of control riding for various orgs around the country, and I can no longer read this thread. It makes my mind go to mush!!
Instead of sitting at home reading 19 different theories on the same thing, go up to Loudon, sit your ass in each corner during the Expert races, and watch how the top guys do it. Over, and over, and over, and over. I still do it!
a) for sure
b) no way![]()
Best advice I can give you:
Penguin 2-day pro school. Very low student-to-instructor ratio, lots of time riding and talking with some of the fastest guys on all different sorts of bikes, from I4s to SVs to (gasp) motards. Just being able to talk to Eric (who has done thousands of laps at Loudon on just about every bike out there) will give you more information than you can absorb.
don't brake going into T9
