On their site they say 3/4" thick plywood to be mounted on, would it be ok to mount it on 5/8" plywood?
CCS #31
I've seen people use supports under the floor to help stabilize the system. Basically they get longer bolts big washers and steel strapping to gain leverage of the plate to frame rails under the floor rather than just mounting to the floor. Or reinforce the floor from the under side with some well placed square tubing held with the mounting bolts.
I need to order these for my toy hauler. Too many other projects!!!
Should be fine if you use a good sized backing plate on the underside.
