What does everyone do between race weekends as far as maintaining your machines? I'm especially curious to hear from those of you that also use your race machine for frequent track days.
Mild to wild... watcha got?
Wirelessly posted (my phone: Mozilla/4.1 (compatible; MSIE 6.0; ) 400x240 LGE VX10000)
Change oil, tires. Inspect everything. Coolant, brakes, nuts, bolts, safety wire.This is usually done the night before the next event.![]()
Cover with a tarp after unhooking trailer.
Uncover and hook trailer up when I'm ready to head south to NHMS.
In all seriousness, I check my oil, go over the bike visually and with my hands, poking and prodding, plus look at the one or two lil issues I noted at the track, like this time it was converting my belly pan to dzus fasteners so I don't have to take the rearsets off to remove it, and flushing my front and rear brake as the fluid had juuuust started to take on a tint. My GS is easy on the oil, I expect I can go a full season without changing it and it won't really bother it.
I drain my engine oil and tranny oil and put new stuff in, Clean oil filter, check over bolts. Check coolant repeatedly. Wipe down with a rag/cleaner to keep her fresh
This week I am adding a rebuild to waterpump as long as my frickin parts get here...they are on a plane right now.
LRRS #399
MX #505
LRRS #399
MX #505
Oil & Filter Change every other weekend
Brake Fluids after 4 race weekends
Rebuild Brake calipers after brake pad change
Suspension at beginning of season. Sometimes mid-season as well
Grease axles once a weekend
scotchbrite the rotors every other weekend
i think thats about it
i'm going to throw it out there that it's a good thing to do the suspension mid-season. you will notice a difference.
LRRS EX #165 (formerly)
modern bike tires rotate on the bearings, the axle is static and the wheel doesn't rotate on it. how does this help?
btw, i do almost nothing between races: when i get up to the track on a friday night i plug in the battery charger (total loss system), wipe her down, check the chain, check the front brake and give her a quick once over.
oil gets changed once, maybe twice a season, at most. brake fluid is changed when then stop grabbing in a frightening way.
occasionally i also totally f-up my geometry by screwing with suspension. i wouldn't recommend doing this though. it's doesn't help![]()
Scott
Wow, lots and lots of dirty air filters out there i guess.
The wheels rotate on the bearings. The tires don't touch the bearings
The bearings are not a friction fit on the axle. You really should lube the axle with waterproof grease, if only to keep corrosion away. One day you WILL get a stuck axle and you will remember this thread.![]()
It can't be that bad, can it?
There is a lot that surprises me here.
I have never had a race bike, but a race car. Following what I did for weekly maintenance on my car my bike maint would look like this.
Each time,
clean air filter
check all bolts/nuts
chain tension, clean and lube
check tires, change as needed
battery on tender
Every other time,
Oil and filter change
Every 4 races,
Brake fluid change/check pads
mid season,
Suspension
Now obviously a crash or off track excursion would mean a whole different strategy.
In many cases, a 'dirty' K&N will work better than a clean K&N. K&Ns on many bikes flow too well, creating excess turbulence in the airbox, which costs you midrange/partial throttle power. Sure, you may gain a bit on top... but at least at Loudon a solid midrange seems like a better goal vs blowing everything for a killer peak number. Now, there is a point of diminishing returns, followed by rapid losses, but perfectly clean may not be the ideal spot on that curve depending on your bike.![]()
