So as some of you know, I ended last race weekend (which was an AWESOME weekend for me) with a bang, and threw the bike across the bowl. Turns out in that crash I screwed up the transmission, among other things. That left me with a new goal for the break between race weekends: Turn a 100% stock/street EX into the new race bike. I've been going nuts on it, alternating between working to pay for crap and 10 hour days wrenching.
So far, this is a rough list of what I've done (I'm sure I'll forget a bunch of stuff)
- Swap complete front end
- Swap shocks
- Swap rearsets
- Bend left rearset back to acceptable position
- Swap clipons
- swap bodywork (except fairing, which is @ bodywork guys getting repaired)
- Oil & filter change
- Flush coolant
- Clean entire damn bike (had been outside since 06)
- Safety wire and drill almost everything
- Bleed front brake
- Swap rear wheel
- New gearing
- New battery
- Remove all street crap I don't want/need
- Rig choke
- 1/4 turn throttle
- Catch can and tubing
This is what's left, that I can think off. Somehow this list keeps growing as I get farther into the build:
- Front sprocket swap, cut new chain to proper length
- Add distilled water and water wetter (drained the coolant yesterday, then never made it by the store for distilled water)
- Replace brake pads and wire pinch bolts (bolts are drilled, new pads are @ the track)
- Clipon tube and clutch lever (on order)
- New shifter and shift rod (on order)
- Remove side and center stands (leaving this toward last since they are handy while working on it)
- New air filter (on order)
- Drill and wire banjo bolts for rear brake
- Case guards
- Matching grips
- Shock spacer (on order)
- Check valves
Next weekend seems REALLY close right now. Especially considering I really want to make Thursday practice to give the thing a shakedown and have Friday to deal with whatever comes up in the shakedown run.
I've never ridden this bike. I didn't even know if it ran and shifted until recently. Parking lot shakedown early next week (as soon as that shock spacer comes in). The real test, of course, will be the track.
And, just because I needed an extra challenge, my finger is still killing me.
Eh, I'll get it done. Hell or high water, that bike WILL be completed and I WILL be there. That said, I've already done more work to this bike than I did to the previous bike for the entire couple years I owned and raced it. This is a LOT of wrenching to me.
It's amazing what some of us put ourselves(and families) thru just to race... but nothing compares to it... after last time, I was flyin' high for days after the event! Good luck bro, you'll get back what you put in, at least emotionally!
LRRS am #121
Drill banjo bolts?
Do they not have to be wired? They were on my last race bike, so I assumed I should on this one too. If I'm wrong that'd save me some time.
edit: This bike will probably see NJMP this season, so "lrrs doesn't check it" won't cut it. I want to be able to pass CCS tech at other tracks. Yes, I know I'll need a belly pan.
Banjo bolts are supposed to be wired.
Have you checked the valves yet on that motor?
Leave the plugs in, spraybomb the plug recesses with brake and parts cleaner, then blow out as much mung as you can with an air gun BEFORE you try and take the valve cover off again. A hand impact driver and the right bit should make detaching the water pipes from the head doable, if not have grease ready to lube them up when you go to re-install.
I'd come down and help but I'm having no luck with oncall coverage assistance yet... :/
LRRS Am #331
Not one banjo bolt wired on mine. Bah. I'm nuts, living on the edge. Sometimes I run with scissors.
LRRS #387
Holy shit, really?! Um... ok. As for where to drill, I do have a spare but would rather use it if I mess something up. I plan to drill just like the ones on the other bike are drilled.
Pfft... I was seen last race weekend on a pedal bike riding with no helmet, an open beer and a fixed blade buck knife in my hands (no joke). I'm concerned with passing various tech inspections, that's all.
You drill through the entire bolt head? That's easy peasy. The ones on the previous EX are drilled through just a corner.
I've come to the conclusion that if banjos are even slightly loose, there will be fluid leaking from the washers. If it comes loose during a race then it wasn't properly tightened to begin with and was likely leaking prior to entering the racing surface.
In short, banjos are either tight or leaking.
Again, MHO
Looks like Fishtail is having some racing school that Thursday instead of the typical open practice... (Maybe the NH Cycling club will let you out on track with them?)
http://www.nhms.com/schedule/
Roland Arsenault
LRRS and USCRA #763
Or get everything done by Sunday and shake down at BoMo on Monday?
Roland Arsenault
LRRS and USCRA #763
Down to the wire, I like it. Its like trying to see how far you can push past E on your gas guage without running out of gas.
I'm almost to the point where I can't do anymore until my parts come in. Finished the drilling and wiring, new sprockets are on, and some other misc. stuff (some of which wasn't even done on my last bike, like drilling/wiring the bolts for the front sprocket).
About to research how to set chain length and try to do that. Sidestand is off, I'm leaving the center stand for last because it's so handy while working on it. New (GP) shifter is on.
I've had overheating problems with the other bike so I'm going to leave the radiator fan on for now. The whole assembly can't weigh more than 3lbs. Not a lot on a production bike. If the bike isn't running hot in a couple months I'll pull the stuff off. Or maybe I'll pull it now and put it back on if it gets too hot. I'm not sure, probably depends if I run out of other stuff to do waiting on parts.
