Results 1 to 22 of 22
Spare front ends kicking around?
    So, I'm putting together a bike for LRRS next year, and I think it needs upside down boingers up front to look pretty, but my budget is already shot. Anyone got a lead on a modern sportbike front end (wheel, forks, clamps, brakes) for cheapy cheap? I've got a serviceable standard damping rod front end so I'm not desperate, but I won't pass up an upgrade if it's cheap enough.
    (I love the auto-generated tag suggestions... spare, front, ends, kicking)
    Lifer eboos's Avatar
    Re: Spare front ends kicking around?
    How about an X1 front end?
    Posting Freak FAST GSXR750's Avatar
    Granby Ct.
    Friend of mine has a gsxr inverted fork set up. I'll ask him what he wants for it if you're interested.
    GSXR750 GS650 Street Tracker
    Quote Originally Posted by eboos View Post
    I hadn't considered the Buell option, lemmie bounce that off Mr Kates seeing as he'll be the one revalving it. How did you like the ZTL brake setup? I've heard people claim it can have chatter issues?
    Edit: The X1 didn't HAVE the ZTL setup, my memory is faulty I think.
    Quote Originally Posted by FAST GSXR750 View Post
    I'm interested, please do!
    lol, didn't you have an X1 at one point?
    These forks were Mark Reynolds when he was racing in the Lightning Series and were built by Traction Dynamics. They were freshened up when I got them last year. 1.0kg springs, and several sets of preload spacers to give a 10mm range of adjustment (no external preload adjuster).
    Closest I ever came to owning a Buell was a used green S2T I test rode and quite liked and was strongly considering as an upgrade for my Honda V65 Sabre. I test rode a Ducati ST3 that same year and ended up going the Italian route instead. I've since had a very short ride on a hopped up to hell Cyclone on the street, never got to try an XB based mount.
    Do you have a complete front end or just the forks?
    Almost complete front end. Needs clipons (54mm) and master cylinder. Also have second front wheel.
    I ganked the master cylinder from him.
    You bastard!
    I do have a Nissin 17mm MC that I used to use with this setup. The Brembo 16mm flet better.
    i can get you some forks off a 86 ZX600
    #331 CBR929RE's Avatar
    Bridgewater, MA
    those ain't USD. and they probably weight about 100lbs.
    so, its a whole front end for probably free. you have USD forks that dont weigh 100lbs, and youre slow as shit
    Bridgewater, MA
    I know, imagine how slow I was back when I had an 86 ZX600.
    Those are about the same tech level I'm currently at, decent damping rod based standard suspenders with ok brakes. I was advised 'USD anything' as where to look next so I appreciate the offer but they don't quite match my search criteria at the moment.
    call kickstands and wheelies
    Ok, what is up with almost every front end setup on eBay not including the top clamp? They'll sell the forks, brakes, clipons, masters, switch clusters, and the lower clamp but not the upper?
    Member dudutzu's Avatar
    I think is has to do with the ignition switch, the ignition switch bolts on most bikes are made to be impossible to take out(unless...) so for the people parting out bikes its just easier not to deal with that, and sell the ignition with the other locks as a set instead with the top clamp
    This guy has a 99-01 GSXR 1000 forks for sale call him if you interested...upsidedownones
    978-265-9353
    Granby Ct.
    I"ve got an 04 gsxr600 inverted w/ aprox 4k miles. Both clamps, brakes complete less the wheel. $500 out the door. Deliverable to NHMS.
    Dr Q : Last resort Medic Qfactor's Avatar
    Homeless, MA
    I have R1 forks and a plethora of gsxr front end parts hanging around...
    interested?
    Q
    So, official marching orders are 01 or later GSXR inverted/upside down front end. I need the whole shebang, clamps, wheel, brakes, those stretchy bits that connect the forks to the clamps, etc.
    I'm also flying the cheap card as always.
  1. Anyone have a spare front warmer?
    By Philkinson in forum Pit Area
    Last Post: 08-16-15, 07:13 AM
  2. spare front stand available in the infield?
    By brady in forum Pit Area
    Last Post: 04-21-15, 09:01 PM
  3. Anyone got a spare front warmer?
    Last Post: 09-14-14, 04:16 AM
  4. Kicking off the season ....
    By Not Sure in forum Rides & Events
    Last Post: 04-20-14, 05:58 AM
