Results 1 to 8 of 8
Spun bearing???
    AM #152 tropicoz's Avatar
    Apr 2010
    Maine
    Spun bearing???
    R6 motor, if it spun a bearing will it knock continuously as it runs, or will it come and go with revs? Looking at a motor that knocks at idle, then quiets down for a second or two, then knocks again in repetition. Seems to keep quiet when revs stay higher.
    Senior Member myzx6's Avatar
    Apr 2014
    Riviera beach fl
    Re: Spun bearing???
    Usually spun bearings knock consistently with engine speed but not always, some will only knock at idle. From what you describe its most likely a spun bearing but you never know till you open the engine up.
    Apr 2010
    Maine
    Re: Spun bearing???
    Derry NH
    Re: Spun bearing???
    That definitely doesn't sound like a rod bearing. It sounds like something's loose, possibly in the transmission area.
    Typically this is what rod knock will sound like, though this is a car.
    Re: Spun bearing???
    I agree with Eric. Sounds like something in the clutch or tranny.
    Lifer Danz19899's Avatar
    Grafton, Ma
    Re: Spun bearing???
    Agreed doesn't sound bottom end to me. Does sound like something bad inside the clutch or tranny. Does pulling the clutch lever or putting it into gear affect it at all?
    www.bostonmoto.com
    Ride to live, live to ride
    Apr 2010
    Maine
    Re: Spun bearing???
    I'll run it through the gears today to see if it continues making the noise in gear. Glad to hear it might not be the bottom end, but it's still a major repair if it's the gearbox, no? Any of you done a tranny rebuild (and I don't mean you Smutty, with your cross dressing and all!)?
    Re: Spun bearing???
    They can be a little annoying to use but have you tried an automotive stethoscope? You should be able to get one at Sears or the like. Or you could do the ghettofabulous method which is use a screwdriver (or something solid) by putting one end on the case and one end in your rear.. erm.. ear.
  1. Wanted - Parts & Tools | WTB Wheel bearing
    By RC5150 in forum Wanted
    Last Post: 09-22-14, 06:05 PM
  2. Wheel Bearing Help
    By HanktheTank in forum Bike Maintenance
    Last Post: 01-10-12, 10:46 AM
  3. Headset Bearing
    By DBB in forum Dirty Bastards
    Last Post: 03-25-10, 03:32 PM
  4. Bad Head bearing
    By 00cbr_f4 in forum Bike Maintenance
    Last Post: 07-28-09, 07:54 AM
  5. Bearing Removal.
    By oreo_n2 in forum Bike Maintenance
    Last Post: 10-03-02, 09:29 PM
