Results 1 to 17 of 17
Tire Warmer temps for various brands
    aka Johnny Valve Stem need4speed's Avatar
    Aug 2002
    Brookfield,CT
    Found this info on the WERA site.
    Thought this might help.
    This info was gathered by Sam Flemming of AoD/Roadracing World fame. I cut out the recommendation list and taped it to my Chickhawk Carrying case. The article did not mention the variables for the different compounds. If I recall correctly, all the numbers were retrieved from the reps of their respective brands:
    Bridgestone ~ 80 - 90C (60-80C for 250's) @ 30-45 Min
    Dunlop ~ 75 - 80C @ 45-60 Min
    Pirelli ~ 50-60C @ 20-30 Min
    Michelin ~ 90C @ 45-60 Min
    John
    LRRS\CCS #714
    2004 Duc 620 monster racebike
    89 EX500 racebike - sold
    98 Superhawk 996
    "To repeat what others have said, requires education; to challenge it, requires brains".
    Good shit. But how do you monitor the temp? How do we control the temp? On, off, on, off? Seriously...
    I have the newer Chickenhawk warmers that have a replaceable resistor that sets the temp where I want it.
    derek
    Lifer legalspeed's Avatar
    Somersworth, NH
    The woods put in a rheostat in line with the power.
    chicken hawks have different thermostats.
    LRRS\CCS\WERA #486
    Aug 2002
    Brookfield,CT
    The Pole Position Chicken Hawks come with 2 thermostats. 175 & 135 degrees F. Chickenhawk standard (not pole position) are regulated to 175 deg.
    John
    LRRS\CCS #714
    98 Superhawk 996
    Walpole
    I bet it would be pretty easy to fabricate something to turn on and off the heat where you desire.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Ed and Jay, the already have the thermostats. If you watch them, they switch on and off automatically anyway. Standard CH warmers are regulated to 175f as John said.
    derek
    Walpole
    Oh I realize that otherwise they would have a melt down.
    I am thinking of a variable t-stat that will let you choose what temp you would like. Think of the benifits here, you dont like to keep them on all the time because 175 is a bit much for constant heating and kills the life of the tire.
    Lets say you keep it at an idle temp off track at like 120 then turn it up before racing to get them at proper temp for the race. Normally you get back and the warmers go on without power to conserve the heat in the tire and then on before the race. If you can keep them at a happy medium between races you should get a better tire life.
    Another benifit would be to try different temps for different track conditions,tire manufactuers etc.... I know Dan started a log of tire temps and density changes last year before and after each race. If we could also have more freedom to try different temps vs. compounds it may turn out to be a little edge that you can use when deciding on what tires you may want to buy or use in that race.
    .02 cents
    2000 Ducati 900ss
    Aug 2002
    Brookfield,CT
    Degs,
    Which chicken hawks do you have, as the standard ones only come with one setting - 175 F .
    John
    LRRS\CCS #714
    98 Superhawk 996
    Originally posted by need4speed
    Degs,
    Pole position ones with multiple thermostats.
    degs
    Angry Man Racing Collision pro's Avatar
    Jan 2003
    NC
    degs
    Have you ever used the other thermostats?
    Collision Pros Racing
    Yep, if I have a long delay between races I will put on the low temp thermostat.
    derek
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    How long of a delay Degs? I had a lengthy conversation with the Michelin guy and he claims it is not good as it ultimately creates one very long heat cycle.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Well, if there is a 45 minute to 1 hour delay I'll put the low temp on. Over that and I'll just cover the tires with the warmers and leave them unplugged.
    derek
    Aug 2002
    Brookfield,CT
    Kevin,
    What would you say would be the minimum amount of heat time to be sufficient?
    John
    LRRS\CCS #714
    98 Superhawk 996
    Northshore/Beverly, MA
    Invest in one of those infrared thermometers...Just point and shoot, will give you all the info you need, then adjust thermostats accordingly.
    Jan 2003
    NC
    Just leave them on all day.......less heat cycles!!
  1. Repair a tire warmer?
    By pontifex in forum Bike Maintenance
    Last Post: 08-27-13, 09:31 AM
  2. Replies: 6
    Last Post: 04-24-13, 08:05 PM
  3. WTB-rear tire warmer
    By hotducati in forum Wanted
    Last Post: 07-09-12, 09:43 PM
  4. DMP digital tire warmer
    By j4eric in forum General Bike Related
    Last Post: 03-11-11, 08:48 PM
  5. Tire Warmer Special
    By gmdboston in forum Pit Area
    Last Post: 03-26-07, 04:41 PM
